As installing docker in containers using zfs is problematic I thought I’d create a btrfs storage.
That all works fine however if I want to add or remove a device from btrfs how do that within the LXD storage context?.
The issue is that created my btrfs storage from a single partition… #lxc storage create btrfs btrfs source=/dev/ubuntu-vg/lxd-btrfs-0-lv
I’ve created a second btrfs partition and I’ld like to add it to the first…
From a CLI point of view I’d expect todo…
btrfs device add /dev/mapper/ubuntu–vg-lxd–btrfs–1–lv /mnt
But of course I’ve not for this partition mounted… So how do I tell lxd to use both for this storage?
