I am trying to build LXC 2.0 on Ubuntu 18.04 and I am getting following error:-
./autogen.sh
- test -d autom4te.cache
- libtoolize
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, ‘config’.
libtoolize: error: linking ‘/usr/share/libtool/build-aux/ltmain.sh’ to ‘config/’ failed
libtoolize: putting macros in ‘config’.
libtoolize: error: linking ‘/usr/share/aclocal/libtool.m4’ to ‘config/’ failed
libtoolize: error: linking ‘/usr/share/aclocal/ltoptions.m4’ to ‘config/’ failed
libtoolize: error: linking ‘/usr/share/aclocal/ltsugar.m4’ to ‘config/’ failed
libtoolize: error: linking ‘/usr/share/aclocal/ltversion.m4’ to ‘config/’ failed
libtoolize: error: linking ‘/usr/share/aclocal/lt~obsolete.m4’ to ‘config/’ failed
libtoolize: Consider adding ‘AC_CONFIG_MACRO_DIRS([config])’ to configure.ac,
libtoolize: and rerunning libtoolize and aclocal. - exit 1
The automake version that I am using is : 1.15.1
The same source I am able to build successfully in Ubuntu 14.04 which is having automake version 1.14.1
Can some one please tell me what is the issue here?
Thanks,
