I first noticed this saturday the 25th when I rebooted my VM and it did not come back up.
As of a few days I can no longer reboot my VMs hosted on Ceph RBD storage:
error reading conf file /etc/ceph/ceph.conf: Permission denied
This may very well be an issue for a longer time as I haven’t had time to manage my infrastructure for the past few weeks.
root @ node3 # ls -l /etc/ceph/ceph.conf
-rw-r----- 1 root root 556 Sep 17 2020 /etc/ceph/ceph.conf
root @ node3 # snap list
core18 20220428 2409 latest/stable canonical✓ base
core20 20220527 1518 latest/stable canonical✓ base
lxd 5.2-79c3c3b 23155 latest/stable canonical✓ in-cohort
snapd 2.56 16010 latest/stable canonical✓ snapd
root @ node3 # lxc start transmission2
Error: Failed setting up device via monitor: Failed adding block device for disk device "root": Failed adding block device: error reading conf file /etc/ceph/ceph.conf: Permission denied
Try `lxc info --show-log transmission2` for more info
My LXC guests that have their disk on Ceph RBD can start just fine!
Changing the permissions of /etc/ceph and /etc/ceph/ceph.conf to 777/644 allows me to start my VMs again but obviously this is not something that is feasible.
changing ownership of /etc/ceph and /etc/ceph/ceph.conf to root:lxd with the original permissions also doesn’t work. What permissions do I need for this file + directory?
Timestamp on /etc/ceph says May 20, according to my unattended-upgrades log ceph packages were upgraded on that day to 16.2.9-1focal.
I know that @stgraber also runs on Ceph so I am curious to know if you also have this issue
root @ node2 # lxc info --show-log transmission2
Status: STOPPED
Type: virtual-machine
Created: 2021/03/01 11:45 CET
Last Used: 2022/06/28 10:01 CEST
Log:
warning: tap: open vhost char device failed: Permission denied
root @ node2 # ls -la /etc/ceph
total 28
drwxr-x--- 2 root root 4096 May 20 06:49 .
drwxr-xr-x 120 root root 12288 Jun 28 06:21 ..
-rw-r----- 1 root root 64 Sep 24 2020 ceph.client.admin.keyring
-rw-r----- 1 root root 556 Sep 24 2020 ceph.conf
-rw------- 1 root root 84 Sep 24 2020 ceph.keyring
root @ node2 # chmod 755 /etc/ceph
root @ node2 # lxc start transmission2
works :-)
755 on /etc/ceph works, 750 on /etc/ceph does not work. Both with root:root and root:lxd as owner on directory and ceph.conf.
The funny thing about this test is that I leave ceph.conf on 640 in both cases… I’m a bit confused because of that.
root @ node2 # stat /etc/ceph
File: /etc/ceph
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: fd03h/64771d Inode: 525230 Links: 2
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2022-06-28 10:02:45.973027312 +0200
Modify: 2022-05-20 06:49:19.454047867 +0200
Change: 2022-06-28 10:05:05.776382866 +0200
Birth: -
root @ node2 # stat /etc/ceph/ceph.conf
File: /etc/ceph/ceph.conf
Size: 556 Blocks: 8 IO Block: 4096 regular file
Device: fd03h/64771d Inode: 525491 Links: 1
Access: (0640/-rw-r-----) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2022-06-28 10:03:34.532801869 +0200
Modify: 2020-09-24 10:11:02.923594501 +0200
Change: 2022-06-28 10:02:46.913022928 +0200
Birth: -
