Hello all,
I can access docker containers running in lxc container from the LAN but I can’t access them using Wireguard VPN on the new LXC containers that I create.
I’m using a Raspberry Pi 5 with Raspberry Pi OS Lite (64-bit).
There I installed Incus using the Zabbly package repository (stable) starting with version 6.2.
Using that version I created two containers with images:debian/12 (they are called first and pihole)
My main use is hosting a few docker containers (pihole, linkding, mealie, swag and others) inside the lxc containers.
I’m using the default bridge to add the lxc containers:
ipv4.address: 10.51.53.1/24
ipv4.nat: "true"
ipv6.address: fd42:95d6:5a11:20a1::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/first
- /1.0/instances/pihole
- /1.0/instances/test
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
project: default
I’m able to access the services running in the containers using network forward:
$ incus network forward list incusbr0
| LISTEN ADDRESS | DESCRIPTION | DEFAULT TARGET ADDRESS | PORTS |
| 192.168.60.101 | docker applications | | 17 |
for example I can access linkding with
http://192.168.60.101:9090
from the incus host, from a laptop on the same LAN and from another laptop using wireguard VPN in another town.
Then I did the upgrade to incus 6.5 to try the docker integration on the LXC host.
After that I wanted to create a new lxc container to host some docker containers. I followed the same steps to create the lxc containers as I did for first and pihole.
I was able to run another instance of linkding on port 9901.
I added that port on the same incus network forward with port 9901.
Here comes the problem:
I’m able to access the new linkding service with
http://192.168.60.101:9901
from the incus host, from a laptop on the same LAN but I can’t access it using wireguard VPN.
The services on the first two containers are not affected. They work as usual. The problem occurs only on new lxc containers.
I also tried the following: I did a copy of first container to first-copy and gave it a different IP. I changed the network forward to use the new lxc container (with the new IP) and I have the same problem even with that container. I can access the services from Incus host, from the LAN but not using wireguard VPN.
Is there a new configuration that I have to set to access the LXC containers from outside the LAN?
Thank you in advance!
Edit:
I get timeout when I try to access the service on the new lxc container using wireguard.
