My goal is to build a PXE server running tftp.
Let’s say that the PXE server is running in a managed network named pxe-net.
Everything works fine from host, I can ping from host and the command below succeded.
host:~$ tftp -m binary <ip_pxe> -c get ipxe.efi
The problem comes when I try to run the same command from another container B in another managed network, let’s say incusbr0.
Pinging from B to pxe_server succeded but tftp from B to pxe_server fails.
My first thought is that UDP traffic is blocked between networks, but he following test is successfull.
pxe_srv:~# nc -u -l 4000
B:~# nc -u <ip_pxe_server> 4000
Here is the dump from tcpdump in both containers and the same request from host with success.
B requesting ipxe.efi*
16:12:51.007707 IP 10.149.165.224.41962 > 10.0.10.66.69: TFTP, length 17, RRQ "ipxe.efi" octet
16:12:53.447630 IP 10.149.165.1.60414 > 239.255.255.250.1900: UDP, length 101
16:12:53.518926 IP 10.149.165.1.35915 > 10.149.165.255.32412: UDP, length 21
16:12:53.518928 IP 10.149.165.1.39617 > 10.149.165.255.32414: UDP, length 21
pxe_server listening on port 69 (tftp) on request from B FAILS*
16:12:56.007939 IP 10.0.10.100.41962 > 10.0.10.66.69: TFTP, length 17, RRQ "ipxe.efi" octet
16:12:56.012454 IP 10.0.10.66.50948 > 10.0.10.100.41962: UDP, length 516
16:12:56.012546 IP 10.0.10.100 > 10.0.10.66: ICMP 10.0.10.100 udp port 41962 unreachable, length 552
pxe_server listening on port 69 (tftp) on request from host SUCCESS*
6:41:52.863961 IP 10.0.10.100.51531 > 10.0.10.66.69: TFTP, length 17, RRQ "ipxe.efi" octet
16:41:52.869931 IP 10.0.10.66.51562 > 10.0.10.100.51531: UDP, length 516
16:41:52.870137 IP 10.0.10.100.51531 > 10.0.10.66.51562: UDP, length 4
16:41:52.870239 IP 10.0.10.66.51562 > 10.0.10.100.51531: UDP, length 516
16:41:52.870349 IP 10.0.10.100.51531 > 10.0.10.66.51562: UDP, length 4
16:41:52.870405 IP 10.0.10.66.51562 > 10.0.10.100.51531: UDP, length 516
16:41:52.870549 IP 10.0.10.100.51531 > 10.0.10.66.51562: UDP, length 4
I can see that tftp request from B fails because related efimeral port 41692 to gateway isn’t unreachable.
Any ideas?
Might be firewal rules that incus creates wrong?
Thanks.
