Cannot copy/move from a remote into a cluster with --target
My question is: why can’t we use --target when moving a container into a cluster?
We have a cluster (now with three nodes) and a few “old” LXD nodes. It is possible to add the old LXD nodes as remote on one of the cluster nodes. (And main cluster node is a remote on the old LXD nodes.)
This way it is possible to copy or move containers into the cluster. So far so good. But I would like to be able to place these migration containers on one specific node of the cluster. That is currently not possible, it seems. The cluster picks a node.
My use case is the new nodes in the cluster have more memory and SSDs. So I want to place the more demanding containers on the new cluster node.
What happens now is that I first move the container into the cluster and then I move them to a specific target. You can image that this is time consuming when containers are over 100GB in size.
Let’s look at the error I’m getting
root@ijssel:~# lxc cluster list
|  NAME  |            URL            | DATABASE | STATE  |      MESSAGE      | ARCHITECTURE |
| ijssel | https://172.16.16.54:8443 | YES      | ONLINE | fully operational | x86_64       |
| luts   | https://172.16.16.45:8443 | YES      | ONLINE | fully operational | x86_64       |
| rijn   | https://172.16.16.59:8443 | YES      | ONLINE | fully operational | x86_64       |
root@ijssel:~# lxc remote list
|      NAME       |                   URL                    |   PROTOCOL    |  AUTH TYPE  | PUBLIC | STATIC |
| roer            | https://roer.ghs.nl:8443                 | lxd           | tls         | NO     | NO     |
root@ijssel:~# lxc move roer:cocoon cocoon --target luts
Error: The source LXD server is not clustered
root@ijssel:~# lxc ls|grep cocoon
| cocoon                        | STOPPED |                      |      | CONTAINER | 0         | rijn     |
https://github.com/lxc/lxd/pull/7709
:slight_smile: :+1:
