When i want to create a new storage pool the underlined losetup command gives a error
output
incus storage create data btrfs
Error: Failed to run: losetup --find --nooverlap --direct-io=on --show /var/lib/incus/disks/data.img: exit status 1 (losetup: unrecognized option: find
BusyBox v1.38.0 (2026-09-12 12:01:17 UTC) multi-call binary.
Usage: losetup [-rP] [-o OFS] {-f|LOOPDEV} FILE: associate loop devices
losetup -c LOOPDEV: reread file size
losetup -d LOOPDEV: disassociate
losetup -a: show status
losetup -f: show next free loop device
-o OFS Start OFS bytes into FILE
-P Scan for partitions
-r Read-only
-f Show/use next free loop device)
losetup is a symlink to busybox :0
installing incus on a existing btrfs partion gives no problem to mount on the /var/lib/incus/storage-pool
blkid
/dev/sda3: UUID="72..." TYPE="btrfs"
/dev/sda2: UUID="68..." TYPE="swap"
/dev/sda1: UUID="74.." TYPE="vfat"
/dev/sdb1 UUID="123" TYPE=btrfs
incus storage show default
source: /var/lib/incus/storage-pools/default
volatile.initial_source: /var/lib/incus/storage-pools/default
driver: btrfs
Is the another way to create a storage pool ?
