Cannot start a wireguard interface in an unprivileged container
I have lxc installed on an OpenWrt host. I cannot bring up a wireguard interface in an unprivileged container and am wondering why. From reading it seems that CAP_NET_ADMIN needs to be given to the container but I am unsure how to do it. If I understand correctly, lxc.cap.drop = will grant all capabilities to the container yet it is not working:
# wg-quick up outside
[#] ip link add outside type wireguard
[#] wg setconf outside /dev/fd/63
[#] ip -4 address add 10.xxx.xxx.xxx/32 dev outside
[#] ip link set mtu 1320 up dev outside
[#] resolvconf -a outside -m 0 -x
[#] wg set outside fwmark 51820
[#] ip -4 route add 0.0.0.0/0 dev outside table 51820
[#] ip -4 rule add not fwmark 51820 table 51820
[#] ip -4 rule add table main suppress_prefixlength 0
[#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
[#] iptables-restore -n
iptables-restore v1.8.10 (legacy): iptables-restore: unable to initialize table 'raw'
Error occurred at line: 1
Try `iptables-restore -h' or 'iptables-restore --help' for more information.
[#] resolvconf -d outside -f
[#] ip -4 rule delete table 51820
[#] ip -4 rule delete table main suppress_prefixlength 0
[#] ip link delete dev outside
In searching I found this thread but in my case, I have the wireguard module loaded on the host. Could the issue be with my container config?
# Distribution configuration
lxc.arch = aarch64
lxc.idmap = u 0 100000 65536
lxc.idmap = g 0 100000 65536
lxc.cap.drop =
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = br-lan
lxc.net.0.veth.vlan.id = 10
lxc.net.0.ipv4.address = 10.9.8.252/24
lxc.net.0.ipv4.gateway = 10.9.8.1
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:a8:3f:4a
## mounts
lxc.mount.entry = /mnt/data/lxc/shared-pkg-cache var/cache/pacman/pkg none bind 0 0
lxc.mount.entry = /mnt/data/incoming incoming none bind 0 0
lxc.rootfs.path = overlay:/mnt/data/lxc/base/rootfs:/mnt/data/lxc/libre/overlay/delta
lxc.uts.name = libre
The error isn’t about the wireguard module, it’s about access to the raw netfilter table, the module for that likely isn’t already loaded on the host.
Thanks for the reply @stgraber. That was the problem. I found that I could totally omit the lxc.cap.drop = line after loading iptable_raw.ko on the host. Is that to be expected with an unprivileged container?
