Hi, I’m trying to run an unprivileged LXD container.
Adding lxc config set lwt security.privileged true
works but as soon as I lxc config unset lwt security.privileged
I get
Error: Failed to run: /usr/bin/lxd forkstart lwt /var/lib/lxd/containers /var/log/lxd/lwt/lxc.conf: Try
lxc info --show-log lwt for more info
[lxd@tp s]$ cat /etc/subuid
lxd:1000000:65536
root:1000000:65536
[lxd@tp s]$ cat /etc/subgid
lxd:1000000:65536
root:1000000:65536
Output of lxc info --show-log lwt
Status: STOPPED
Type: container
Created: 2021/11/30 18:08 EET
Last Used: 2021/11/30 18:48 EET
Log:
lxc lwt 20211130164811.361 TRACE commands - commands.c:lxc_cmd:509 - Connection refused - Command "get_state" failed to connect command socket
lxc lwt 20211130164811.361 TRACE start - start.c:lxc_init_handler:740 - Created anonymous pair {3,7} of unix sockets
lxc lwt 20211130164811.361 TRACE commands - commands.c:lxc_server_init:2069 - Created abstract unix socket "/var/lib/lxd/containers/lwt/command"
lxc lwt 20211130164811.361 TRACE start - start.c:lxc_init_handler:756 - Unix domain socket 9 for command server is ready
lxc lwt 20211130164811.361 INFO lxccontainer - lxccontainer.c:do_lxcapi_start:987 - Set process title to [lxc monitor] /var/lib/lxd/containers lwt
lxc lwt 20211130164811.362 INFO start - start.c:lxc_check_inherited:328 - Closed inherited fd 4
lxc lwt 20211130164811.362 INFO start - start.c:lxc_check_inherited:328 - Closed inherited fd 5
lxc lwt 20211130164811.362 INFO start - start.c:lxc_check_inherited:328 - Closed inherited fd 6
lxc lwt 20211130164811.362 INFO start - start.c:lxc_check_inherited:328 - Closed inherited fd 13
lxc lwt 20211130164811.362 INFO start - start.c:lxc_check_inherited:328 - Closed inherited fd 25
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_start:2186 - Doing lxc_start
lxc lwt 20211130164811.362 INFO lsm - lsm/lsm.c:lsm_init_static:38 - Initialized LSM security driver nop
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_init:780 - Initialized LSM
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_serve_state_clients:486 - Set container state to STARTING
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_serve_state_clients:489 - No state clients registered
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_init:786 - Set container state to "STARTING"
lxc lwt 20211130164811.362 TRACE start - start.c:lxc_init:842 - Set environment variables
lxc lwt 20211130164811.362 INFO conf - conf.c:run_script_argv:340 - Executing script "/proc/19467/exe callhook /var/lib/lxd "default" "lwt" start" for container "lwt"
lxc lwt 20211130164811.362 TRACE conf - conf.c:run_script_argv:383 - Set environment variable: LXC_HOOK_TYPE=pre-start
lxc lwt 20211130164811.362 TRACE conf - conf.c:run_script_argv:388 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc lwt 20211130164811.362 DEBUG lxccontainer - lxccontainer.c:wait_on_daemonized_start:848 - First child 30028 exited
lxc lwt 20211130164811.415 TRACE start - start.c:lxc_init:847 - Ran pre-start hooks
lxc lwt 20211130164811.415 TRACE start - start.c:setup_signal_fd:373 - Created signal file descriptor 5
lxc lwt 20211130164811.415 TRACE start - start.c:lxc_init:860 - Set up signal fd
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at misc and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the misc controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at rdma and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the rdma controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at pids and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the pids controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at hugetlb and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the hugetlb controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at net_prio and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the net_prio controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at perf_event and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the perf_event controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at net_cls and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the net_cls controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at freezer and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the freezer controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at devices and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the devices controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at memory and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the memory controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at blkio and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the blkio controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at cpuacct and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the cpuacct controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at cpu and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the cpu controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at cpuset and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the cpuset controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at openrc and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:459 - The hierarchy contains the name=openrc controller
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__initialize_cgroups:3192 - No controllers are enabled for delegation in the unified hierarchy
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:cgroup_hierarchy_add:456 - Adding cgroup hierarchy mounted at unified and base cgroup (null)
lxc lwt 20211130164811.415 TRACE cgroup - cgroups/cgroup.c:cgroup_init:40 - Initialized cgroup driver cgfsng
lxc lwt 20211130164811.415 TRACE cgroup - cgroups/cgroup.c:cgroup_init:45 - Hybrid cgroup layout
lxc lwt 20211130164811.415 TRACE start - start.c:lxc_init:867 - Initialized cgroup driver
lxc lwt 20211130164811.415 DEBUG seccomp - seccomp.c:parse_config_v2:656 - Host native arch is [3221225534]
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:get_new_ctx:470 - Added arch 2 to main seccomp context
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:get_new_ctx:478 - Removed native arch from main seccomp context
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:get_new_ctx:470 - Added arch 3 to main seccomp context
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:get_new_ctx:483 - Arch 4 already present in main seccomp context
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "[all]"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "reject_force_umount # comment this to allow umount -f; not recommended"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:524 - Set seccomp rule to reject force umounts
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "kexec_load errno 38"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding native rule for syscall[246:kexec_load] action[327718:errno] arch[0]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741827]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[246:kexec_load] action[327718:errno] arch[1073741886]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "open_by_handle_at errno 38"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding native rule for syscall[304:open_by_handle_at] action[327718:errno] arch[0]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741827]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[304:open_by_handle_at] action[327718:errno] arch[1073741886]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "init_module errno 38"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding native rule for syscall[175:init_module] action[327718:errno] arch[0]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741827]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[175:init_module] action[327718:errno] arch[1073741886]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "finit_module errno 38"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding native rule for syscall[313:finit_module] action[327718:errno] arch[0]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741827]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[313:finit_module] action[327718:errno] arch[1073741886]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:807 - Processing "delete_module errno 38"
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding native rule for syscall[176:delete_module] action[327718:errno] arch[0]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741827]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:do_resolve_add_rule:564 - Adding compat rule for syscall[176:delete_module] action[327718:errno] arch[1073741886]
lxc lwt 20211130164811.415 INFO seccomp - seccomp.c:parse_config_v2:1017 - Merging compat seccomp contexts into main context
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:parse_config_v2:1027 - Merged first compat seccomp context into main context
lxc lwt 20211130164811.415 TRACE seccomp - seccomp.c:parse_config_v2:1043 - Merged second compat seccomp context into main context
lxc lwt 20211130164811.415 TRACE start - start.c:lxc_init:874 - Read seccomp policy
lxc lwt 20211130164811.415 TRACE start - start.c:lxc_init:881 - Initialized LSM
lxc lwt 20211130164811.415 INFO start - start.c:lxc_init:883 - Container "lwt" is initialized
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 10(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 11(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 12(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 13(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 14(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 15(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.415 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 16(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 17(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 18(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 19(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 20(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 21(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.416 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 22(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 23(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:626 - No isolated or offline cpus present in cpuset
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:640 - Copied cpu settings of parent cgroup
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_initialize:676 - Initialized cpuset in the legacy hierarchy
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 24(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.432 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 25(lxc.monitor.lwt) cgroup
lxc lwt 20211130164811.432 INFO cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1028 - The monitor process uses "lxc.monitor.lwt" as cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 26
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 26
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 27
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 27
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 28
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 28
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 29
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 29
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 30
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 30
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 31
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 31
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 32
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 32
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 33
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 33
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 34
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 34
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 35
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 35
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 36
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 36
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 37
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 37
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 38
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 38
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 39
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 39
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 40
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 40
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1178 - Moved monitor into cgroup 41
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_enter:1187 - Moved transient process into cgroup 41
lxc lwt 20211130164811.433 DEBUG storage - storage/storage.c:get_storage_by_name:209 - Detected rootfs type "dir"
lxc lwt 20211130164811.433 TRACE conf - conf.c:lxc_rootfs_init:555 - Not pinning because container runs in user namespace
lxc lwt 20211130164811.433 TRACE sync - sync.c:lxc_sync_init:139 - Initialized synchronization infrastructure
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 10(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 11(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 12(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 13(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 14(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 15(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 16(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 17(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 18(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 19(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.433 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 20(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 21(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 22(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 23(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:626 - No isolated or offline cpus present in cpuset
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:640 - Copied cpu settings of parent cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_initialize:676 - Initialized cpuset in the legacy hierarchy
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 24(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Created 25(lxc.payload.lwt) cgroup
lxc lwt 20211130164811.434 INFO cgfsng - cgroups/cgfsng.c:cgfsng_payload_create:1136 - The container process uses "lxc.payload.lwt" as inner and "lxc.payload.lwt" as limit cgroup
lxc lwt 20211130164811.435 TRACE start - start.c:lxc_spawn:1704 - Spawned container directly into target cgroup via cgroup2 fd 46
lxc lwt 20211130164811.435 TRACE start - start.c:lxc_spawn:1744 - Cloned child process 30038
lxc lwt 20211130164811.452 TRACE start - start.c:core_scheduling:1584 - Created new core scheduling domain with cookie 1794762921
lxc lwt 20211130164811.452 TRACE utils - utils.c:lxc_can_use_pidfd:1801 - Kernel supports pidfds
lxc lwt 20211130164811.452 INFO start - start.c:lxc_spawn:1764 - Cloned CLONE_NEWUSER
lxc lwt 20211130164811.452 INFO start - start.c:lxc_spawn:1764 - Cloned CLONE_NEWNS
lxc lwt 20211130164811.452 INFO start - start.c:lxc_spawn:1764 - Cloned CLONE_NEWPID
lxc lwt 20211130164811.452 INFO start - start.c:lxc_spawn:1764 - Cloned CLONE_NEWUTS
lxc lwt 20211130164811.452 INFO start - start.c:lxc_spawn:1764 - Cloned CLONE_NEWIPC
lxc lwt 20211130164811.452 DEBUG start - start.c:lxc_try_preserve_namespace:139 - Preserved user namespace via fd 48 and stashed path as user:/proc/30029/fd/48
lxc lwt 20211130164811.452 DEBUG start - start.c:lxc_try_preserve_namespace:139 - Preserved mnt namespace via fd 49 and stashed path as mnt:/proc/30029/fd/49
lxc lwt 20211130164811.452 DEBUG start - start.c:lxc_try_preserve_namespace:139 - Preserved pid namespace via fd 50 and stashed path as pid:/proc/30029/fd/50
lxc lwt 20211130164811.452 DEBUG start - start.c:lxc_try_preserve_namespace:139 - Preserved uts namespace via fd 51 and stashed path as uts:/proc/30029/fd/51
lxc lwt 20211130164811.452 DEBUG start - start.c:lxc_try_preserve_namespace:139 - Preserved ipc namespace via fd 52 and stashed path as ipc:/proc/30029/fd/52
lxc lwt 20211130164811.453 DEBUG conf - conf.c:idmaptool_on_path_and_privileged:3509 - The binary "/usr/bin/newuidmap" has CAP_SETUID in its CAP_EFFECTIVE and CAP_PERMITTED sets
lxc lwt 20211130164811.453 DEBUG conf - conf.c:idmaptool_on_path_and_privileged:3515 - The binary "/usr/bin/newgidmap" has CAP_SETGID in its CAP_EFFECTIVE and CAP_PERMITTED sets
lxc lwt 20211130164811.453 DEBUG conf - conf.c:lxc_map_ids:3587 - Functional newuidmap and newgidmap binary found
lxc lwt 20211130164811.453 TRACE sync - sync.c:lxc_sync_wait_parent:110 - Child waiting for parent with sequence startup
lxc lwt 20211130164811.456 ERROR conf - conf.c:lxc_map_ids:3654 - newuidmap failed to write mapping "newuidmap: uid range [0-1000000000) -> [1000000-1001000000) not allowed": newuidmap 30038 0 1000000 1000000000
lxc lwt 20211130164811.456 ERROR start - start.c:lxc_spawn:1790 - Failed to set up id mapping.
lxc lwt 20211130164811.456 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_USER_NS=/proc/30029/fd/48
lxc lwt 20211130164811.456 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_MNT_NS=/proc/30029/fd/49
lxc lwt 20211130164811.456 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_PID_NS=/proc/30029/fd/50
lxc lwt 20211130164811.456 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_UTS_NS=/proc/30029/fd/51
lxc lwt 20211130164811.457 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_IPC_NS=/proc/30029/fd/52
lxc lwt 20211130164811.457 DEBUG network - network.c:lxc_delete_network:4159 - Deleted network devices
lxc lwt 20211130164811.457 TRACE start - start.c:lxc_serve_state_socket_pair:547 - Sent container state "ABORTING" to 7
lxc lwt 20211130164811.457 TRACE start - start.c:lxc_serve_state_clients:486 - Set container state to ABORTING
lxc lwt 20211130164811.457 TRACE start - start.c:lxc_serve_state_clients:489 - No state clients registered
lxc lwt 20211130164811.457 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:867 - Received container state "ABORTING" instead of "RUNNING"
lxc lwt 20211130164811.458 ERROR start - start.c:__lxc_start:2073 - Failed to spawn container "lwt"
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_serve_state_clients:486 - Set container state to ABORTING
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_serve_state_clients:489 - No state clients registered
lxc lwt 20211130164811.458 WARN start - start.c:lxc_abort:1038 - No such process - Failed to send SIGKILL via pidfd 47 for process 30038
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_serve_state_clients:486 - Set container state to STOPPING
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_USER_NS=/proc/30029/fd/48
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_MNT_NS=/proc/30029/fd/49
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_PID_NS=/proc/30029/fd/50
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_UTS_NS=/proc/30029/fd/51
lxc lwt 20211130164811.458 TRACE start - start.c:lxc_expose_namespace_environment:908 - Set environment variable LXC_IPC_NS=/proc/30029/fd/52
lxc lwt 20211130164811.458 INFO conf - conf.c:run_script_argv:340 - Executing script "/usr/bin/lxd callhook /var/lib/lxd "default" "lwt" stopns" for container "lwt"
lxc lwt 20211130164811.458 TRACE conf - conf.c:run_script_argv:383 - Set environment variable: LXC_HOOK_TYPE=stop
lxc lwt 20211130164811.458 TRACE conf - conf.c:run_script_argv:388 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc lwt 20211130164816.467 TRACE conf - conf.c:get_minimal_idmap:4979 - Allocated minimal idmapping for ns uid 0 and ns gid 0
lxc lwt 20211130164816.468 TRACE conf - conf.c:userns_exec_1:5043 - Establishing uid mapping for "30073" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc lwt 20211130164816.468 TRACE conf - conf.c:userns_exec_1:5043 - Establishing uid mapping for "30073" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc lwt 20211130164816.468 TRACE conf - conf.c:userns_exec_1:5043 - Establishing gid mapping for "30073" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc lwt 20211130164816.468 TRACE conf - conf.c:userns_exec_1:5043 - Establishing gid mapping for "30073" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc lwt 20211130164816.468 DEBUG conf - conf.c:idmaptool_on_path_and_privileged:3509 - The binary "/usr/bin/newuidmap" has CAP_SETUID in its CAP_EFFECTIVE and CAP_PERMITTED sets
lxc lwt 20211130164816.468 DEBUG conf - conf.c:idmaptool_on_path_and_privileged:3515 - The binary "/usr/bin/newgidmap" has CAP_SETGID in its CAP_EFFECTIVE and CAP_PERMITTED sets
lxc lwt 20211130164816.468 INFO conf - conf.c:lxc_map_ids:3585 - Caller maps host root. Writing mapping directly
lxc lwt 20211130164816.468 TRACE conf - conf.c:lxc_map_ids:3660 - Wrote mapping "1000000000 0 1
lxc lwt 20211130164816.468 TRACE conf - conf.c:run_userns_fn:4845 - Calling function "cgroup_tree_remove_wrapper"
lxc lwt 20211130164816.468 NOTICE utils - utils.c:lxc_drop_groups:1347 - Dropped supplimentary groups
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 10(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 11(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 12(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 13(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 14(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 15(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 16(lxc.payload.lwt)
lxc lwt 20211130164816.468 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 17(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 18(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 19(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 20(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 21(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 22(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 23(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 24(lxc.payload.lwt)
lxc lwt 20211130164816.469 TRACE cgfsng - cgroups/cgfsng.c:cgroup_tree_remove:485 - Removed cgroup tree 25(lxc.payload.lwt)
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 10(lxc.pivot) cgroup
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 10(lxc.monitor.lwt)
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 11(lxc.pivot) cgroup
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 11(lxc.monitor.lwt)
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 12(lxc.pivot) cgroup
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 12(lxc.monitor.lwt)
lxc lwt 20211130164816.470 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 13(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 13(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 14(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 14(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 15(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 15(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 16(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 16(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 17(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 17(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 18(lxc.pivot) cgroup
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 18(lxc.monitor.lwt)
lxc lwt 20211130164816.471 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 19(lxc.pivot) cgroup
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 19(lxc.monitor.lwt)
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 20(lxc.pivot) cgroup
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 20(lxc.monitor.lwt)
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 21(lxc.pivot) cgroup
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 21(lxc.monitor.lwt)
lxc lwt 20211130164816.472 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 22(lxc.pivot) cgroup
lxc lwt 20211130164816.473 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 22(lxc.monitor.lwt)
lxc lwt 20211130164816.473 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 23(lxc.pivot) cgroup
lxc lwt 20211130164816.473 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:626 - No isolated or offline cpus present in cpuset
lxc lwt 20211130164816.492 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_cpus_initialize:640 - Copied cpu settings of parent cgroup
lxc lwt 20211130164816.493 TRACE cgfsng - cgroups/cgfsng.c:cpuset1_initialize:676 - Initialized cpuset in the legacy hierarchy
lxc lwt 20211130164816.493 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 23(lxc.monitor.lwt)
lxc lwt 20211130164816.493 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 24(lxc.pivot) cgroup
lxc lwt 20211130164816.494 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 24(lxc.monitor.lwt)
lxc lwt 20211130164816.494 TRACE cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:715 - Reusing 25(lxc.pivot) cgroup
lxc lwt 20211130164816.494 TRACE cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:915 - Removed cgroup tree 25(lxc.monitor.lwt)
lxc lwt 20211130164816.494 TRACE start - start.c:lxc_end:965 - Closed command socket
lxc 20211130164816.494 ERROR af_unix - af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc lwt 20211130164816.494 TRACE start - start.c:lxc_end:976 - Set container state to "STOPPED"
lxc 20211130164816.494 ERROR commands - commands.c:lxc_cmd_rsp_recv_fds:127 - Failed to receive file descriptors
lxc 20211130164816.494 TRACE commands - commands.c:lxc_cmd:516 - Opened new command socket connection fd 30 for command "get_state"
lxc lwt 20211130164816.494 INFO conf - conf.c:run_script_argv:340 - Executing script "/usr/share/lxcfs/lxc.reboot.hook" for container "lwt"
lxc lwt 20211130164816.494 TRACE conf - conf.c:run_script_argv:383 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc lwt 20211130164816.494 TRACE conf - conf.c:run_script_argv:388 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc lwt 20211130164817.269 INFO conf - conf.c:run_script_argv:340 - Executing script "/usr/bin/lxd callhook /var/lib/lxd "default" "lwt" stop" for container "lwt"
lxc lwt 20211130164817.277 TRACE conf - conf.c:run_script_argv:383 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc lwt 20211130164817.278 TRACE conf - conf.c:run_script_argv:388 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc 20211130164817.614 TRACE commands - commands.c:lxc_cmd:509 - Connection refused - Command "get_state" failed to connect command socket
lxc 20211130164817.694 TRACE commands - commands.c:lxc_cmd:509 - Connection refused - Command "get_state" failed to connect command socket
lxc 20211130165022.522 TRACE commands - commands.c:lxc_cmd:509 - Connection refused - Command "get_state" failed to connect command socket
lxc 20211130165022.525 TRACE commands - commands.c:lxc_cmd:509 - Connection refused - Command "get_state" failed to connect command socket
[lxd@tp s]$ lxc config show lwt
image.architecture: amd64
image.description: Busybox 1.34.1 amd64 (20211130_06:30)
image.os: Busybox
image.release: 1.34.1
image.serial: “20211130_06:30”
image.type: squashfs
image.variant: default
volatile.base_image: 357ebc6e84a6eb6dcbe3f2bd08a7eb5d1821cde2ddcce9966b93dc6bd038601a
volatile.eth0.host_name: veth9195c658
volatile.eth0.hwaddr: 00:16:3e:5c:40:ac
volatile.idmap.base: “0”
volatile.idmap.current: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.idmap.next: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.last_state.idmap: ‘[]’
volatile.uuid: a528c4c0-2df0-4733-af59-a23d65fd03a3
devices: {}
TIA
