I have a weird issue when i connect to my lan via vpn (both openvpn and wireguard). I cant connect to my containers. My windows VM (lxd) on the same profile works fine. Connections from the host work well. They are on the same nic and subnet. I can also access my routers gui.
The containers are on a macvlan on a secondary nic. The VM is on the same nic and also macvlan (works).
Ports are open on the firewall of the containers.
