Thank you. After the update and re-importing the error was shown:
Error: Failed instance creation: Error transferring instance data: Rsync send failed: clusterNode2/snap1, /var/snap/lxd/common/lxd/storage-pools/default/containers-snapshots/clusterNode2/snap1/: [exit status 11 read unix @lxd/e9f57d63-972e-4ae6-a9d8-5b2c86a14938->@: use of closed network connection] (rsync: write failed on “/var/snap/lxd/common/lxd/storage-pools/default/containers/clusterNode2/rootfs/etc/pki/ca-trust/extracted/pem/email-ca-bundle.pem”: No space left on device (28)
rsync error: error in file IO (code 11) at receiver.c(374) [receiver=3.1.3]
After increasing a disk space the problem was solved.
