Hello, I’m trying to setup a incus cluster. I’m stuck at the storage pool creation (lvmcluster).
I made sure all 3 nodes have access to the shared VG (called nucVG cause it’s on a iSCSI target exposed by a NUC) and all nodes can create and activate VG from it and the locks are working as expected.
hv-01 [~]# incus storage create san lvmcluster lvm.vg_name=nucVG --target hv-01
Storage pool san pending on member hv-01
hv-01 [~]# incus storage create san lvmcluster lvm.vg_name=nucVG --target hv-02
Storage pool san pending on member hv-02
hv-01 [~]# incus storage create san lvmcluster lvm.vg_name=nucVG --target hv-03
Storage pool san pending on member hv-03
Error: lvmcluster requires a shared physical device or a pre-existing shared VG to be used as source
I tried to reproduce with Terraform and there is this error when creating the cluster-wide pool:
│ Error: Provider produced inconsistent result after apply
│ When applying changes to module.storage["san"].incus_storage_pool.this,
│ provider "provider[\"registry.opentofu.org/lxc/incus\"]" produced an
│ unexpected new value: .config: new element "size" has appeared.
│ This is a bug in the provider, which should be reported in the provider's
│ own issue tracker.
After that the pool exists and seems functional in Incus.
