Thanks Simos for trying it yourself. As I am new to all this, I can’t say that I understand each and every word.
When I started rosfoxy container I used a custom profile named ros by following this video. Here it is:
environment.DISPLAY: :0
raw.idmap: both 1000 1000
user.user-data: |
#cloud-config
runcmd:
- "apt-key adv --fetch-keys 'https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc'"
- "apt-add-repository 'http://packages.ros.org/ros/ubuntu'"
- "apt-add-repository 'http://packages.ros.org/ros2/ubuntu'"
description: ROS
X0:
path: /tmp/.X11-unix/X0
source: /tmp/.X11-unix/X0
nictype: bridged
parent: lxdbr0
logitech:
productid: 082b
type: usb
vendorid: 046d
pool: default
- /1.0/instances/rosfoxy
The logitech part was added when I used this command lxc profile device add ros logitech usb vendorid=046d productid=082b
But I have never added gid=1000 when using lxc config device add rosfoxy video0 unix-char path=/dev/video0. So I went ahead and tried:
hany@hany-asus:~$ lxc config device add rosfoxy video0 unix-char path=/dev/video0 gid=1000
Error: The device already exists
hany@hany-asus:~$ lxc config device remove rosfoxy video0 unix-char path=/dev/video0
Error: The device doesn't exist
hany@hany-asus:~$ lxc config device remove rosfoxy video1 unix-char path=/dev/video1
hany@hany-asus:~$ lxc config device remove rosfoxy video2 unix-char path=/dev/video2
hany@hany-asus:~$ lxc config device remove rosfoxy video3 unix-char path=/dev/video3
hany@hany-asus:~$ lxc config device add rosfoxy video2 unix-char path=/dev/video2 gid=1000
Then from inside the container I tried
(base) ubuntu@rosfoxy:~$ v4l2-ctl --all
Failed to open /dev/video0: Permission denied
But when I added sudo I got:
(base) ubuntu@rosfoxy:~$ sudo v4l2-ctl --all
Driver Info:
Driver name : uvcvideo
Card type : Webcam C170: Webcam C170
Bus info : usb-0000:00:14.0-1
Driver version : 5.4.86
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Which seems to me that the webcam is detected!
but guvcview still returns
(base) ubuntu@rosfoxy:~$ guvcview
V4L2_CORE: ERROR opening V4L2 interface for /dev/video0
V4L2_CORE: ERROR opening V4L2 interface for /dev/video1
V4L2_CORE: ERROR opening V4L2 interface for /dev/video2
V4L2_CORE: ERROR opening V4L2 interface for /dev/video3
GUVCVIEW: version 2.0.6
GUVCVIEW: couldn't open /home/ubuntu//.config/guvcview2/video0 for read: No such file or directory
V4L2_CORE: ERROR opening V4L interface: Permission denied
GUVCVIEW (1): Guvcview error
no video device found
and sudo guvcview returns
(base) ubuntu@rosfoxy:~$ sudo guvcview
GUVCVIEW: couldn't open /root/.config/guvcview2/video0 for read: No such file or directory
V4L2_CORE: (UVCIOC_CTRL_MAP) Error: No such file or directory
ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM sysdefault
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_hw.c:1829:(_snd_pcm_hw_open) Invalid value for card
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM default
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM dmix
Segmentation fault
also
(py38) ubuntu@rosfoxy:~$ python -c "import cv2;print(cv2.VideoCapture(0).isOpened())"
[ WARN:0] global ../modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video0): can't open camera by index
False
I wonder why it is so complicated
