Sorry if there are some technical errors & lack of understandings, thinpool lvm storages managed by incus makes my brain fart a lot, thank a lot to anyone helping & for that awesome patience.
☆ミ(o*・ω・)ノ
I have a 48G tar.gz virtual machine (that will be 150G in the end~) that I need to import back into my brand new dedicated lvm thinpool storage, before that it was a lvm loop disk but I managed to break it all.
When I try to import it I have an error that says my backup volume is too little, I’m sorry I don’t have the specific error, here is the error :
Importing instance: 20% (12.54MB/s)Error: write /var/lib/incus/backups/incus_backup_1356021296: no space left on device
I thought thinpool provisionning would avoid me to resize anything but I didn’t understand very well I guess, so my quest now is to try resizing custom_default_backups--vol.
Problem are I have some errors with these commands :
incus storage volume set default backups-vol size=160Gib
Error: Invalid value for volume "default_backups-vol" option "size": Invalid value: 160Gib
I also tried :
Error: In use
But it is not in use :
incus storage volume list default
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| container | nanani | | filesystem | 1 |
| container | nanana | | filesystem | 1 |
| custom | backups-vol | | filesystem | 0 |
| custom | images-vol | | filesystem | 0 |
| virtual-machine | patati | | block | 1 |
And now I don’t have a clue to resize my backup volume (it worked for nanani, nanana & patati although there storage is bigger than 10G, so I’m stuck, would you have clue to resize it ? I’m also ok deleting & recreating it but I’m stuck too (you can see above at « USED BY » column that it is not used) :
incus storage volume delete default custom/backups-vol
Error: The storage volume is still in use
Here are some informations about volume group I’m using which is srv, Data% column is not well shown but there is well and truly 10.71 used on this 360G disk.
lvscan
ACTIVE '/dev/tatatitou-vg/srv' [<359.92 GiB] inherit
ACTIVE '/dev/tatatitou-vg/root' [23.28 GiB] inherit
ACTIVE '/dev/tatatitou-vg/var' [9.22 GiB] inherit
ACTIVE '/dev/tatatitou-vg/swap_1' [976.00 MiB] inherit
ACTIVE '/dev/tatatitou-vg/tmp' [<1.62 GiB] inherit
ACTIVE '/dev/tatatitou-vg/home' [11.00 GiB] inherit
ACTIVE '/dev/tatatitou-vg/custom_default_backups--vol' [10.00 GiB] inherit
ACTIVE '/dev/tatatitou-vg/custom_default_images--vol' [10.00 GiB] inherit
ACTIVE '/dev/tatatitou-vg/containers_nanani' [<18.63 GiB] inherit
ACTIVE '/dev/tatatitou-vg/containers_nanana' [27.94 GiB] inherit
ACTIVE '/dev/tatatitou-vg/virtual-machines_patati.block' [27.94 GiB] inherit
ACTIVE '/dev/tatatitou-vg/virtual-machines_patati' [500.00 MiB] inherit
lvs -a
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
containers_nanani tatatitou-vg Vwi-aotz-k <18.63g srv 42.97
containers_nanana tatatitou-vg Vwi-aotz-k 27.94g srv 68.62
custom_default_backups--vol tatatitou-vg Vwi-aotz-k 10.00g srv 2.27
custom_default_images--vol tatatitou-vg Vwi-aotz-k 10.00g srv 2.26
[lvol0_pmspare] tatatitou-vg ewi------- 92.00m
root tatatitou-vg -wi-ao---- 23.28g
srv tatatitou-vg twi-aotz-- <359.92g 10.71 13.91
[srv_tdata] tatatitou-vg Twi-ao---- <359.92g
[srv_tmeta] tatatitou-vg ewi-ao---- 92.00m
Here is volume show
incus storage volume show default custom/backups-vol
block.filesystem: ext4
block.mount_options: discard
type: custom
used_by: []
content_type: filesystem
project: default
created_at: 2025-05-29T22:51:00.353476482Z
incus storage show default
lvm.thinpool_name: srv
lvm.use_thinpool: "true"
lvm.vg.force_reuse: "true"
lvm.vg_name: tatitou-vg
source: tatitou-vg
volatile.initial_source: tatitou-vg
volume.size: 140GB
driver: lvm
- /1.0/instances/patati
- /1.0/instances/nanani
- /1.0/instances/nanana
- /1.0/storage-pools/default/volumes/custom/backups-vol
- /1.0/storage-pools/default/volumes/custom/images-vol
status: Created
locations:
- none
Would someone have a clue I could dig in to resize backup volume ? Or any other clues about importing my vm ?
Again, thanks a bunch reading this, I will be done about all these questions after this one.
EDIT : added volume backup error I finally found
