First of all thanks for creating lxd, it’s awesome!!
I have set up a 3 node lxd cluster with ceph storage backend. I’ve been trying to get automatic failover by running a simple script that checks ‘lxc cluster ls’. Any containers on a stopped host will be in Error state and my script then just does lxc move && lxc start.
This works mostly, but I’ve ended up with a corrupted filesystem in several containers. I’ve not been able to reproduce the problem, but I can imagine this happens when the lxd cluster communication fails while the individual nodes can still access Ceph. Without proper fencing two nodes may write to the same rbd.
I’m new to ceph, but I noticed it has an exclusive-locks feature:
https://docs.ceph.com/en/latest/rbd/rbd-exclusive-locks/
but lxd doesn’t seem to enable it on the filesystem:
root@miles:~# rbd info lxdpool/container_fileserver
rbd image 'container_fileserver':
size 19 GiB in 4769 objects
order 22 (4 MiB objects)
snapshot_count: 21
block_name_prefix: rbd_data.15452f1b586be
format: 2
features: layering
op_features:
flags:
create_timestamp: Tue Nov 2 11:46:36 2021
access_timestamp: Tue Nov 2 11:46:36 2021
modify_timestamp: Tue Nov 2 11:46:36 2021
parent: lxdpool/zombie_image_7e68080daefdc36d8d7448a29f37bacd9f933f5c99b8556138796ecd38e7f91c_ext4@readonly
overlap: 9.3 GiB
I can enable it manually:
rbd feature enable lxdpool/container_fileserver exclusive-lock
and this doesn’t seem to affect lxd.
Would this prevent potential problems? Shouldn’t lxd enable the exclusive-lock feature on new containers?
Thanks
Joost
