"Cgroup namespace: required" in lxc-checkconfig and CONFIG_CGROUP_NS
That article says I need to enable CONFIG_CGROUP_NS in the kernel.
This page says that the option doesn’t exist in modern kernels.
Should lxc-checkconfig be fixed to not scare people?
Output of lxc-checkconfig
# lxc-checkconfig
LXC version 4.0.0-devel
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
Cgroup v2 mount points:
/sys/fs/cgroup
Cgroup v1 systemd controller: missing
Cgroup v1 freezer controller: missing
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, not loaded
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: missing
CONFIG_NF_NAT_IPV6: missing
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:
Any thoughts @brauner ? Thanks
Cgroup namespaces never had a separate config entry they were always under CONFIG_CGROUPS, i.e. if you have cgroups compiled into the kernel then cgroup namespaces should be available. Afaict, lxc-checkconfig is doing nothing wrong. Specifically the CONFIG_CGROUP_NS entry was something entirely different that had nothing to do with cgroup namespaces per se.
What we can do however, is to add a new entry in lxc-checkconfig that specifically checks for cgroup namespaces by looking at /proc/self/ns/cgroup.
This should do the trick:
