I’m trying out unified cgroups (e.g. no device cgroup). I’m running a self compiled 5.10 kernel with LXD 4.0.9 (also self compiled). (for reasons ™). User namespace is not enabled in this kernel.
When I try to start a privileged container that has a unix-char device forwarded to it, the container fails to start (does not get an IP). The log shows:
$ lxc info --show-log deb11
Remote: unix://
Created: 2022/06/20 13:51 CEST
Status: Running
Type: container
Profiles: default, kmx_latencydev_pf
Pid: 24324
Ips:
eth0: inet6 fe80::216:3eff:fe3b:f9d1 vethed5469fd
lo: inet 127.0.0.1
lo: inet6 ::1
Resources:
Processes: 1
Network usage:
Bytes received: 260B
Bytes sent: 656B
Packets received: 2
Packets sent: 8
lo:
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
Log:
lxc deb11 20220620121909.989 ERROR utils - utils.c:open_devnull:1232 - Operation not permitted - Can't open /dev/null
lxc deb11 20220620121909.989 WARN start - start.c:do_start:1394 - Failed to ajust stdio permissions
The containers configuration:
$ lxc config show -e deb11
boot.autostart: "false"
image.architecture: amd64
image.description: Debian bullseye amd64 (20220620_05:25)
image.os: Debian
image.release: bullseye
image.serial: "20220620_05:25"
image.type: squashfs
image.variant: default
security.privileged: "true"
volatile.base_image: 0e74bd2b1cd760553cc80c902c88fbf9ed0091461deac01bd2ef6bf491eed692
volatile.eth0.host_name: vethed5469fd
volatile.eth0.hwaddr: 00:16:3e:3b:f9:d1
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 6e631b5b-c6f6-4159-b114-2054c9868632
cpu_dma_latency:
gid: "997"
path: /dev/cpu_dma_latency
type: unix-char
nictype: bridged
parent: lxdbr0
pool: default
- kmx_latencydev_pf
When I remove the unix-char device, the container starts alright.
If I now start a 2nd container that has the same unix-char device forwarded to it, the container starts but I get an error inside the log:
$ lxc init -c security.privileged=true -c boot.autostart=false images:debian/11 deb11-2nd
Creating deb11-2nd
$ lxc profile add deb11-2nd kmx_latencydev_pf
Profile kmx_latencydev_pf added to deb11-2nd
$ lxc start deb11-2nd
$ lxc info --show-log deb11-2nd
Remote: unix://
Created: 2022/06/20 14:25 CEST
Status: Running
Type: container
Pid: 25915
Ips:
lo: inet 127.0.0.1
lo: inet6 ::1
eth0: inet 10.0.4.65 vetha8a7a62a
eth0: inet6 fe80::216:3eff:fe02:78b2 vetha8a7a62a
Resources:
Processes: 1
Network usage:
lo:
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
Bytes received: 742B
Bytes sent: 2.32kB
Packets received: 3
Packets sent: 23
Log:
lxc deb11-2nd 20220620122522.944 ERROR cgroup2_devices - cgroups/cgroup2_devices.c:bpf_program_load_kernel:332 - Operation not permitted - Failed to load bpf program: (null)
$ lxc profile show kmx_latencydev_pf
config: {}
description: add cpu_dma latency control to container
cpu_dma_latency:
gid: "997"
type: unix-char
- /1.0/instances/deb11-2nd
