Currently I try to share a folder (storage volume) across some containers.
devices: certs: path: /var/cert pool: storage1 source: certificates type: disk
The volume gets mounted as expected:
[root@nixos:~]# ls -l /var | grep cert drwxrwx--- 4 root root 4096 May 18 22:46 cert
I wonder if there’s a way to grant read, write, execute right to “others”?
chmod 777 /var/cert shoud work fine
chmod 777 /var/cert
Is there another possibility without further container interaction?
Not at this time. We could in theory add a config option for it, but the exact behavior may get confusing (do we re-apply it every time we mount it, is it a one-off thing, …), so no plans on adding such an option right now.
