Checksum errors after installing incus-ui-canonical
I am using the latest Incus 6.0 LTS.
While using my own image server I didn’t had any errors or any checksum errors.
I wanted to install incus-ui-canonical, so I can debug some VM’s.
However when incus-ui-canonical was installed, I ended up getting consistent checksum errors, on images that worked fine before and have not been changed.
Anyone aware of this? some kind of bug?
I mean if the base incus isn’t complaining why is incus complaining when incus-ui-canonical is installed? Either is bugged or incus isn’t doing checksum checks.
Any ideas? I also rebooted the system after installing incus-ui-canonical, no change.
Very unlikely to be related to incus-ui-canonical. All that this package does is write a few HTML, CSS and JS files in /opt/incus/ui/. It doesn’t interact with Incus at all.
It seems more likely that either some other set of packages got pulled in at the same time or that installing the package has somehow upset the storage or kernel on the box causing the other errors.
Incus seems to always get the wrong checksum
root@baguette:~# wget -c https://img.someimageserver.net/images/alpine/3.23/amd64/cloud/20260509_11:54/incus.tar.xz
–2026-05-09 17:45:55--  https://img.someimageserver.net/images/alpine/3.23/amd64/cloud/20260509_11:54/incus.tar.xz
Resolving img.someimageserver.net (img.someimageserver.net)… xxx.xxx.xxx.xxx
Connecting to img.someimageserver.net (img.someimageserver.net)|xxx.xxx.xx.xxx|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 1312 (1.3K) [application/octet-stream]
Saving to: ‘incus.tar.xz’
incus.tar.xz                                               100%[========================================================================================================================================>]   1.28K  --.-KB/s    in 0s
2026-05-09 17:45:56 (15.3 MB/s) - ‘incus.tar.xz’ saved [1312/1312]
root@baguette:~# sha256sum incus.tar.xz
14bdfb71087baec4357452ce082061e3c6ef0861d7ec2d1354b7b1fb1606aee2  incus.tar.xz
root@baguette:~# incus image copy kvm:alpine/3.23/cloud/amd64 local: --alias alpine323
Error: Failed remote image download: Image fingerprint doesn’t match. Got 48831a7b7a4e84fa0431fd4263bbd875205c229156af96caed29a983517ac636 expected 14bdfb71087baec4357452ce082061e3c6ef0861d7ec2d1354b7b1fb1606aee2
root@baguette:~# incus image info kvm:alpine/3.23/cloud/amd64
Fingerprint: 14bdfb71087baec4357452ce082061e3c6ef0861d7ec2d1354b7b1fb1606aee2
Type: virtual-machine
Public: yes
Timestamps:
    Created: 2026/05/09 00:00 UTC
    Uploaded: 2026/05/09 00:00 UTC
    Expires: 1970/01/01 00:00 UTC
    Last used: never
Properties:
    requirements.cdrom_agent: true
    type: disk-kvm.img
    release: 3.23
    variant: cloud
    os: Alpine
    architecture: amd64
    serial: 20260509_11:54
    description: Alpine 3.23 amd64 (20260509_11:54)
Aliases:
    - alpine/3.23/cloud
    - alpine/3.23/cloud/amd64
Cached: no
Auto update: disabled
Profiles: []
I could reproduce that on 2 machines, I thought its a bug on one machine, but nah.
Do you see the same problem with the public image server (images:)?
That one works fine, I double checked everything.
I have no idea why this keeps happening.
I did manually download the files, sums match, I checked the json files with the sha sums, they match.
