I’m trying to follow the instructions here to do some initial configuration of new containers, but I can’t seem to get it to work. Using the image ubuntu:20.04, I’ve created the following profile:
$ lxc profile show psanford-default
user.user-data: |
runcmd:
- [touch, /root/hello]
description: psanford cloud-init
devices: {}
used_by: []
My default profile (which I don’t believe I’ve changed) looks like this:
config: {}
nictype: bridged
parent: lxdbr0
pool: lxdpool
I’m launching the container using the following command:
$ lxc launch ubuntu:20.04 user-data-0 --profile=default --profile=psanford-default
Creating user-data-0
Starting user-data-0
Exec’ing into the container, I can see the config gets placed at /var/lib/cloud/seed/nocloud-net/user-data:
root@user-data-0:~# cat /var/lib/cloud/seed/nocloud-net/user-data
runcmd:
I can also see from the cloud-init.log file that this config gets read, but I don’t see any logs of cloud-init actually attempting to parse and load this config:
2021-08-20 19:10:37,179 - util.py[DEBUG]: Read 33 bytes from /var/lib/cloud/seed/nocloud-net/user-data
2021-08-20 19:10:37,179 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/meta-data (quiet=False)
2021-08-20 19:10:37,179 - util.py[DEBUG]: Read 54 bytes from /var/lib/cloud/seed/nocloud-net/meta-data
2021-08-20 19:10:37,179 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/vendor-data (quiet=False)
2021-08-20 19:10:37,179 - util.py[DEBUG]: Read 18 bytes from /var/lib/cloud/seed/nocloud-net/vendor-data
2021-08-20 19:10:37,179 - util.py[DEBUG]: Reading from /var/lib/cloud/seed/nocloud-net/network-config (quiet=False)
2021-08-20 19:10:37,179 - util.py[DEBUG]: Read 121 bytes from /var/lib/cloud/seed/nocloud-net/network-config
2021-08-20 19:10:37,179 - DataSourceNoCloud.py[DEBUG]: Using seeded data from /var/lib/cloud/seed/nocloud-net
2021-08-20 19:10:37,179 - util.py[DEBUG]: Attempting to load yaml from string of length 54 with allowed root types (<class 'dict'>,)
2021-08-20 19:10:37,180 - util.py[DEBUG]: Attempting to load yaml from string of length 121 with allowed root types (<class 'dict'>,)
2021-08-20 19:10:37,197 - util.py[DEBUG]: Reading from /etc/os-release (quiet=False)
2021-08-20 19:10:37,197 - util.py[DEBUG]: Read 382 bytes from /etc/os-release
Note in the above logs, we see cloud-init reading this file, but we don’t have a corresponding Attempting to load yaml from string of length 33 like we do for the meta-data and network-config.
What am I doing wrong that is keeping cloud-init from using my user-data config?
Edit: I’ve uploaded the full contents of cloud-init.log and cloud-init-output.log to here: user-data-0 cloud-init logs · GitHub
