Upgraded from 4.10 (non-snap) to latest snap version (5.15).
Cluster consists of four nodes, did the following steps on three of them and everything went fine:
snap install lxd
lxd.migrate
Three nodes are now waiting for the last node, however lxd won’t start on the fourth.
Did the same steps but something must have failed and now lxd won’t start on the last node.
output from lxd --debug --group lxd
INFO[07-21|18:50:50] LXD 4.10 is starting in normal mode path=/var/lib/lxd
INFO[07-21|18:50:50] Kernel uid/gid map:
INFO[07-21|18:50:50] - u 0 0 4294967295
INFO[07-21|18:50:50] - g 0 0 4294967295
INFO[07-21|18:50:50] Configured LXD uid/gid map:
INFO[07-21|18:50:50] - u 0 1000000 65536
INFO[07-21|18:50:50] - g 0 1000000 65536
INFO[07-21|18:50:50] Kernel features:
INFO[07-21|18:50:50] - closing multiple file descriptors efficiently: yes
INFO[07-21|18:50:50] - netnsid-based network retrieval: yes
INFO[07-21|18:50:50] - pidfds: yes
INFO[07-21|18:50:50] - uevent injection: yes
INFO[07-21|18:50:50] - seccomp listener: yes
INFO[07-21|18:50:50] - seccomp listener continue syscalls: yes
INFO[07-21|18:50:50] - seccomp listener add file descriptors: yes
INFO[07-21|18:50:50] - attach to namespaces via pidfds: yes
INFO[07-21|18:50:50] - safe native terminal allocation : yes
INFO[07-21|18:50:50] - unprivileged file capabilities: yes
INFO[07-21|18:50:50] - cgroup layout: hybrid
WARN[07-21|18:50:50] - Couldn't find the CGroup blkio.weight, disk priority will be ignored
INFO[07-21|18:50:50] - shiftfs support: yes
INFO[07-21|18:50:50] Initializing local database
DBUG[07-21|18:50:50] Initializing database gateway
DBUG[07-21|18:50:50] Start database node role=voter id=6 address=10.0.0.3:8443
INFO[07-21|18:50:50] Starting cluster handler:
INFO[07-21|18:50:50] Starting /dev/lxd handler:
INFO[07-21|18:50:50] - binding devlxd socket socket=/var/lib/lxd/devlxd/sock
INFO[07-21|18:50:50] REST API daemon:
INFO[07-21|18:50:50] - binding Unix socket socket=/var/lib/lxd/unix.socket
INFO[07-21|18:50:50] - binding TCP socket socket=10.0.0.3:8443
INFO[07-21|18:50:50] Initializing global database
DBUG[07-21|18:50:50] Dqlite: attempt 0: server 10.0.0.1:8443: connected
DBUG[07-21|18:50:50] Database error: &errors.errorString{s:"this node's version is behind, please upgrade"}
EROR[07-21|18:50:50] Failed to start the daemon: failed to open cluster database: failed to ensure schema: this node's version is behind, please upgrade
INFO[07-21|18:50:50] Starting shutdown sequence
INFO[07-21|18:50:50] Stop database gateway
INFO[07-21|18:50:50] Stopping REST API handler:
INFO[07-21|18:50:50] - closing socket socket=10.0.0.3:8443
INFO[07-21|18:50:50] - closing socket socket=/var/lib/lxd/unix.socket
INFO[07-21|18:50:50] Stopping /dev/lxd handler:
INFO[07-21|18:50:50] - closing socket socket=/var/lib/lxd/devlxd/sock
DBUG[07-21|18:50:50] Not unmounting temporary filesystems (containers are still running)
Error: failed to open cluster database: failed to ensure schema: this node's version is behind, please upgrade
