Hello. I made some mistake and now I need you help guys
Basically im hosting two servers with LXD workloads for semi professional appliances. Everything seems fine since yesterday. I dropped one of my server about 5cm above shelf, but it was enough - something happened with sdd. I saw some issues in journal about filesystem errors. Reinstalling ssd in socket helped. Somehow…
None of my lxd containers/vms dont want to start.
$ lxc start tank
Error: saving config file for the container failed
Try `lxc info --show-log tank` for more info
$ lxc info --show-log tank
Status: STOPPED
Type: container
Created: 2023/09/23 14:11 UTC
Last Used: 2024/04/09 14:23 UTC
Log:
Yep. No logs at all.
Here is what I found:
Those are logs from journal. I dont think they are important
Apr 09 17:41:20 hammer systemd-networkd[827]: veth986feada: Link UP
Apr 09 17:41:20 hammer networkd-dispatcher[859]: WARNING:Unknown index 13 seen, reloading interface list
Apr 09 17:41:20 hammer systemd-udevd[3107]: Using default interface naming scheme 'v249'.
Apr 09 17:41:20 hammer NetworkManager[853]: <info> [1712684480.7943] manager: (vethc310e3df): new Veth device (/org/freedesktop/NetworkManager/Devices/13)
Apr 09 17:41:20 hammer systemd-udevd[3109]: Using default interface naming scheme 'v249'.
Apr 09 17:41:20 hammer NetworkManager[853]: <info> [1712684480.7958] manager: (veth986feada): new Veth device (/org/freedesktop/NetworkManager/Devices/14)
Apr 09 17:41:20 hammer kernel: br0: port 2(veth986feada) entered blocking state
Apr 09 17:41:20 hammer kernel: br0: port 2(veth986feada) entered disabled state
Apr 09 17:41:20 hammer kernel: device veth986feada entered promiscuous mode
Apr 09 17:41:20 hammer kernel: device veth986feada left promiscuous mode
Apr 09 17:41:20 hammer networkd-dispatcher[859]: WARNING:Unknown index 14 seen, reloading interface list
Apr 09 17:41:20 hammer systemd-networkd[827]: veth986feada: Link DOWN
Apr 09 17:41:20 hammer NetworkManager[853]: <info> [1712684480.9004] device (veth986feada): released from master device br0
Apr 09 17:41:20 hammer networkd-dispatcher[859]: ERROR:Unknown interface index 14 seen even after reload
Apr 09 17:42:22 hammer systemd[1856]: Started snap.lxd.lxc-9e3af830-1c94-4088-88b5-58f65d499cfc.scope.
And here is somerthing more interesting and I think its root cause. When Im trying to edit any profile/configuration, anything in lxd here is what I get:
- Project: default, Instance: smith-1: Failed to write backup file: Failed to create file "/var/snap/lxd/common/lxd/virtual-machines/smith-1/backup.yaml": open /var/snap/lxd/common/lxd/virtual-machines/smith-1/backup.yaml: read-only file system
- Project: default, Instance: agent-1: Failed to write backup file: Failed to create file "/var/snap/lxd/common/lxd/virtual-machines/agent-1/backup.yaml": open /var/snap/lxd/common/lxd/virtual-machines/agent-1/backup.yaml: read-only file system
SSD is visible withing lsblk. sudo smartctl -H /dev/sda
shows it passes all tests. Its formatted in btrfs and btrfs check
ends with success
sda 8:0 0 1.8T 0 disk
└─sda1 8:1 0 1.8T 0 part
I would be really happy if there is anything I can do to restore that data.
Some informations about my setup:
Intel NUC + nvme + ssd (ssd was used for lxd storage exclusively, nvme for boot)
Ubuntu server 22.04 with LXD 5.20
I would love to restore data from two containers at least. I can setup host from scratch. I just want to restore that database… Any ideas or I already lose?
