Yeah, my containers are running but are useless since they lost all their IPs. What is best way to fix this. I would hate to just reboot blindly and make it worse.
These automatic upgrades are a bad idea.
I restarted individual container - does not make a difference.
Can you show dmesg and cat /var/log/snap/lxd/common/lxd/logs/lxd.log on an affected node?
Also showing lxc network show NAME --target NODE for one of the affected nodes may be useful.
It sounds like it may be the apparmor profile for dnsmasq getting in the way somehow.
cat: /var/log/snap/lxd/common/lxd/logs/lxd.log: No such file or directory
Ok, that output is unrelated to apparmor, so not the issue.
Maybe try grep -i apparmor /var/log/kernel.log to get those potential failures specifically.
Oops, cat /var/snap/lxd/common/lxd/logs/lxd.log I think it is.
| WP-VIRTUALLY2025-2020-MAY29 | RUNNING | | | CONTAINER | 0 | Q1 |
| WP-VIRTUALLY2025-2020-MAY29-bk-Jul20-2020 | STOPPED | | | CONTAINER | 0 | Q4 |
| WP-WARHAPPENS-2020-APR29 | RUNNING | | | CONTAINER | 0 | Q1 |
| WP-WARHAPPENS-2020-APR29-bk-Jul20-2020 | STOPPED | | | CONTAINER | 0 | Q4 |
| WPZ-DATABASE | RUNNING | | | CONTAINER | 0 | Q1 |
| WPZ-DATABASE-bk-Jul20-2020 | STOPPED | | | CONTAINER | 0 | Q4 |
| WW-CCNESNOTICIAS-2020-mar28 | RUNNING | | | CONTAINER | 0 | Q3 |
| lxdMosaic2020B2 | STOPPED | | | CONTAINER | 0 | Q4 |
Yeah, I was hoping for a LXD log entry when network is brought up as that’s when things may have failed.
Anyway, please provide as requested:
lxc network show NETWORK-NAME --target AFFECTED-NODEgrep -i apparmor /var/log/kern.logIt’s almost certainly the new security layer around dnsmasq that’s missing something used in your environment but we need to see what’s failing and what the config is like.
Aug 3 10:17:51 Q2 kernel: [1425893.134362] audit: type=1400 audit(1596464271.492:127): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name="/snap/core/9665/usr/lib/snapd/snap-confine" pid=30337 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.134369] audit: type=1400 audit(1596464271.492:128): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name="/snap/core/9665/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=30337 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.226234] audit: type=1400 audit(1596464271.584:129): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.hook.install” pid=30345 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.238259] audit: type=1400 audit(1596464271.596:130): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.lxd” pid=30349 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.238375] audit: type=1400 audit(1596464271.596:131): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.migrate” pid=30350 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.238776] audit: type=1400 audit(1596464271.596:132): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.buginfo” pid=30341 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.239570] audit: type=1400 audit(1596464271.596:133): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.lxc” pid=30347 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.239605] audit: type=1400 audit(1596464271.596:134): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.activate” pid=30339 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.239668] audit: type=1400 audit(1596464271.596:135): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.check-kernel” pid=30342 comm=“apparmor_parser”
Aug 3 10:17:51 Q2 kernel: [1425893.240457] audit: type=1400 audit(1596464271.596:136): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.lxd.hook.remove” pid=30346 comm=“apparmor_parser”
Aug 3 10:18:09 Q2 kernel: [1425910.676796] audit: type=1400 audit(1596464289.032:144): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lxd_dnsmasq-lxdfan0_</var/snap/lxd/common/lxd>” pid=30916 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435219.697090] audit: type=1400 audit(1596473598.070:145): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>” pid=24125 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.333829] audit: type=1400 audit(1596473598.706:146): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name="/usr/bin/lxc-start" pid=24630 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.334339] audit: type=1400 audit(1596473598.710:147): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name="/usr/lib/snapd/snap-confine" pid=24632 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.334346] audit: type=1400 audit(1596473598.710:148): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=24632 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.334866] audit: type=1400 audit(1596473598.710:149): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name="/usr/bin/man" pid=24631 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.334872] audit: type=1400 audit(1596473598.710:150): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name=“man_filter” pid=24631 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.334877] audit: type=1400 audit(1596473598.710:151): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name=“man_groff” pid=24631 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.336922] audit: type=1400 audit(1596473598.710:152): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name=“lxc-container-default” pid=24627 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.336929] audit: type=1400 audit(1596473598.710:153): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name=“lxc-container-default-cgns” pid=24627 comm=“apparmor_parser”
Aug 3 12:53:18 Q2 kernel: [1435220.336933] audit: type=1400 audit(1596473598.710:154): apparmor=“STATUS” operation=“profile_load” label=“lxd-UVIPIN-2020-MAY11_</var/snap/lxd/common/lxd>//&:lxd-UVIPIN-2020-MAY11_:unconfined” name=“lxc-container-default-with-mounting” pid=24627 comm=“apparmor_parser”
lxc network show NETWORK-NAME --target Q1
Error: not found
Not sure what network name is
Only security that I explicit setup is UFW
Can you show output of lxc network list please
lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| enp1s0 | physical | NO | | | | 0 | |
| enp2s0 | physical | NO | | | | 0 | |
| lxdfan0 | bridge | YES | | | | 167 | CREATED |
So lxdfan0 is the network name, so:
lxc network show lxdfan0 --target Q1
Thanks
root@Q2:/home/ic2000# lxc network show lxdfan0 --target Q2
bridge.mode: fan
fan.underlay_subnet: 84.17.40.0/24
description: “”
type: bridge
And can you see dnsmasq running on that node:
ps aux | grep dnsmasq
lxd 30919 0.0 0.0 49968 3680 ? Ss 10:18 0:01 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=lxdfan0 --listen-address=240.19.0.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdfan0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdfan0/dnsmasq.hosts --dhcp-range 240.19.0.2,240.19.0.254,1h -s lxd -S /lxd/240.19.0.1#1053 --rev-server=240.0.0.0/8,240.19.0.1#1053 --conf-file=/var/snap/lxd/common/lxd/networks/lxdfan0/dnsmasq.raw -u lxd
root 31474 0.0 0.0 14428 1012 pts/0 R+ 13:26 0:00 grep --color=auto dnsmasq
Great thanks, so dnsmasq is running.
Also can you show output of ip a on your host?
ip a
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:30:48:cf:7c:4c brd ff:ff:ff:ff:ff:ff
inet 84.17.40.19/26 brd 84.17.40.63 scope global noprefixroute enp1s0
inet6 fe80::85e2:7c79:defd:ade1/64 scope link noprefixroute
3: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 00:30:48:cf:7c:4d brd ff:ff:ff:ff:ff:ff
4: lxdfan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueue state UP group default qlen 1000
link/ether 02:f0:ac:00:7b:b8 brd ff:ff:ff:ff:ff:ff
inet 240.19.0.1/8 scope global lxdfan0
inet6 fe80::d0e9:96ff:fe67:4cba/64 scope link
16: vethf27985a3@if15: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueue master lxdfan0 state UP group default qlen 1000
link/ether 8e:f4:b9:f7:fd:0c brd ff:ff:ff:ff:ff:ff link-netnsid 1
17: lxdfan0-mtu: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1450 qdisc noqueue master lxdfan0 state UNKNOWN group default qlen 1000
link/ether ce:cc:5c:de:d7:94 brd ff:ff:ff:ff:ff:ff
inet6 fe80::cccc:5cff:fede:d794/64 scope link
18: lxdfan0-fan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueue master lxdfan0 state UNKNOWN group default qlen 1000
inet6 fe80::f0:acff:fe00:7bb8/64 scope link
20: vethf9c373d8@if19: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueue master lxdfan0 state UP group default qlen 1000
link/ether 3e:c0:87:3c:98:a2 brd ff:ff:ff:ff:ff:ff link-netnsid 0
Please can you show the output of lxc config show <container> --expanded where <container> is one of your affected container’s name.
Then also, inside the affected container, please can you manually add an IP to it using the command:
ip a add 240.19.0.x/24 dev eth0
Where the .x part is a free IP in your subnet, you can pick any one in the range 240.19.0.2 to 240.19.0.254
Then inside the container show output of:
ip a
ip r
and
ping 240.19.0.1 -c 5
What I’m trying to ascertain is whether the bridge is functioning correctly, i.e can you ping the gateway, and whether its specifically something blocking DHCP requests to dnsmasq.
