Cluster with different machines
Hi all,
I just setup a new cluster with identical machines and it works well. Now I would like to setup another on a different site but on this sites i have only 2 identical machines and the other has different storage:
  • 2 HPE dl360 gen 9 with 2 x2TB storage
  • 1 dl160 gen10 with 2x1TB storage
is this possible to build a cluster using zfs on it even if their storage is different? It’s not clear fromthe doc if it needs a storage pool Ith the same name on each nodes or if each pool need also to have the same size. What the size parameter does?
Yes, it is possible. Storage name must be identical on cluster members but size can be different.
Perfect :slight_smile: thanks for the answer!
See also
