Communication-Aware scheduler
I want to make a scheduler that considers communication between containers.
Is there a way to determine from the master node in an LXD cluster consisting of master, worker1, and worker2 nodes whether container A located on worker1 and container B located on worker2 are communicating with each other?
Not really, no. You’d need to start dumping and analyzing network traffic, but that’s not exactly a lightweight thing to do :slight_smile:
Hi, have you solved this problem? I also need a communication-aware scheduler at present. Thank you!
