Configuring `ufw` inside an Incus container returns ` ERROR: initcaps...`
Hello
I have an Incus container based on image images:ubuntu/focal/cloud.
ufw was not installed by default in the container so I installed it: sudo apt install ufw
But then when I try to configure ufw (i.e., sudo ufw allow ...), I get the following error:
ERROR: initcaps
[Errno 2] modprobe: FATAL: Module ip6_tables not found in directory /lib/modules/6.8.0-45-generic
ip6tables v1.8.4 (legacy): can't initialize ip6tables table `filter': Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
Any idea what may cause this issue inside the container ?
It looks like a case where the kernel module is not loaded on the host, therefore the functionality is not available in the container.
You can load the kernel module on the host and then try again.
If that now works for you, you can setup this container so that when it is started in the future, it will automatically load any required kernel modules.
You do so with the configuration linux.kernel_modules.
Thanks for your reply @simos !
Actually I cannot find module ip6_tables on the host. In particular, here is the list of files & directories in /lib/modules/6.8.0-45-generic (on the host):
build              modules.builtin            modules.dep.bin  modules.symbols.bin
initrd             modules.builtin.alias.bin  modules.devname  updates
kernel             modules.builtin.bin        modules.order    vdso
modules.alias      modules.builtin.modinfo    modules.softdep
modules.alias.bin  modules.dep                modules.symbols
(no ip6_tables.ko file)
I have done few additional tests:
Host:
  • ditribution: Ubuntu 24.04.1 LTS
  • ufw is installed and works fine (in particular, the above bug does not occur)
Container:
  • when the container image is images:ubuntu/20.04/cloud then the bug occurs
  • when the container image is images:ubuntu/22.04/cloud then ufw works perfectly fine in the container (no bug)
  • when the container image is images:ubuntu/24.04/cloud then ufw works perfectly fine in the container (no bug)
I could reproduce the above scenarios both on my personal laptop and on a server.
It seems the kernel modules used by ufw in Ubuntu 20 were different than those used by Ubuntu 22 onwards (at least this is what I understand). And since containers are using the kernel modules of the host, ufw cannot work on Ubuntu 20 containers.
Is my understanding correct ? Or is it due to a kernel incompatibility ? Is there a workaround (I need ubuntu 20.04 for one of my apps) ?
To get insight on a kernel module, you would run modinfo on the name.
Per this link, the kernel module first appeared in the Linux kernel since some time ago.
$ modinfo ip6_tables
filename:       /lib/modules/6.8.0-45-generic/kernel/net/ipv6/netfilter/ip6_tables.ko
description:    IPv6 packet filter
author:         Netfilter Core Team <coreteam@netfilter.org>
license:        GPL
srcversion:     1B12640EA5E4D4B35CD41E1
depends:        x_tables
retpoline:      Y
intree:         Y
vermagic:       6.8.0-45-generic SMP preempt mod_unload modversions
Here is me launching a container with Ubuntu 20.04, trying to enable the UFW firewall, failing, then doing modprobe ip6_tables, then succeeding.
$ incus launch images:ubuntu/20.04/cloud focal
Launching focal
$ incus exec focal -- su -l ubuntu
ubuntu@focal:~$ ufw
-bash: ufw: command not found
ubuntu@focal:~$ sudo apt install -y ufw
ubuntu@focal:~$ sudo ufw enable
ERROR: initcaps
ubuntu@focal:~$ logout
$ sudo modprobe ip6_tables
Firewall is active and enabled on system startup
But can we make sure that Incus will load the ip6_tables kernel module when you start those containers that require it? Do the following and that’s it.
incus config set focal linux.kernel_modules ip6_tables
Thanks a lot for the detailed reply @simos
It works on my side too when I follow your steps.
I did not know about modinfo and I had started to look into insmod but modprobe seems better and easier. Many thanks for the tips! :slight_smile:
