Hi, I have setup an ovn network and once I have established the connection to the ovn instance the connection drop suddenly. I cant figure out what is the problem. Can someone help me out what may be wrong with that configuration.
Regards.
Here are the informations.
Client side.
nc -l 1234
Host side.
nc -v 10.10.198.2 1234
Connection to 10.10.198.2 1234 port [tcp/*] succeeded!
lxc network ls
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| br-int | bridge | NO | | | | 0 | |
| enp1s0 | physical | NO | | | | 0 | |
| lxdbr0 | bridge | YES | 10.109.131.1/24 | fd42:591f:483a:b70::1/64 | | 2 | CREATED |
| lxdovn1 | bridge | NO | | | | 0 | |
| ovntest | ovn | YES | 10.10.198.1/24 | fd42:27a3:fa42:8782::1/64 | | 1 | CREATED |
| wlp2s0 | physical | NO | | | | 0 | |
lxc ls
| c1 | RUNNING | 10.10.198.2 (eth0) | fd42:27a3:fa42:8782:216:3eff:fe05:72b9 (eth0) | CONTAINER | 0 |
lxc network show ovntest
bridge.mtu: "1500"
ipv4.address: 10.10.198.1/24
ipv4.nat: "true"
ipv6.address: fd42:27a3:fa42:8782::1/64
ipv6.nat: "true"
network: lxdbr0
volatile.network.ipv4.address: 10.109.131.200
volatile.network.ipv6.address: fd42:591f:483a:b70:216:3eff:fecb:7795
type: ovn
- /1.0/instances/c1
managed: true
status: Created
locations:
- none
ip r
default via 192.168.9.1 dev wlp2s0 proto dhcp metric 600
10.10.198.0/24 via 10.109.131.200 dev lxdbr0
10.109.131.0/24 dev lxdbr0 proto kernel scope link src 10.109.131.1
10.109.131.200 dev lxdbr0 proto static scope link
169.254.0.0/16 dev lxdbr0 scope link metric 1000
192.168.9.0/24 dev wlp2s0 proto kernel scope link src 192.168.9.200 metric 600
Sorry to bumping this thread again but, I have warnings like that.
● ovn-ovsdb-server-nb.service - Open vSwitch database server for OVN Northbound database
Loaded: loaded (/lib/systemd/system/ovn-ovsdb-server-nb.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-07-28 22:27:59 +03; 13min ago
Main PID: 19827 (ovsdb-server)
Tasks: 1 (limit: 4528)
Memory: 3.3M
CGroup: /system.slice/ovn-ovsdb-server-nb.service
└─19827 ovsdb-server -vconsole:off -vfile:info --log-file=/var/log/ovn/ovsdb-server-nb.log --remote=punix:/var/run/ovn/ovnnb_db.sock --pidfile=/var/run/ovn/ovnnb_db.pid --unixctl=/var/run/ovn/ovnnb_db.ctl --remote=db:OVN_Nor>
Jul 28 22:37:20 lxdserver ovsdb-server[19827]: ovs|00009|jsonrpc|WARN|unix#3: receive error: Connection reset by peer
Jul 28 22:37:20 lxdserver ovsdb-server[19827]: ovs|00010|reconnect|WARN|unix#3: connection dropped (Connection reset by peer)
Jul 28 22:37:20 lxdserver ovsdb-server[19827]: ovs|00011|jsonrpc|WARN|unix#4: receive error: Connection reset by peer
Jul 28 22:37:20 lxdserver ovsdb-server[19827]: ovs|00012|reconnect|WARN|unix#4: connection dropped (Connection reset by peer)
Jul 28 22:37:21 lxdserver ovsdb-server[19827]: ovs|00013|jsonrpc|WARN|unix#5: receive error: Connection reset by peer
Jul 28 22:37:21 lxdserver ovsdb-server[19827]: ovs|00014|reconnect|WARN|unix#5: connection dropped (Connection reset by peer)
Jul 28 22:38:09 lxdserver ovsdb-server[19827]: ovs|00015|jsonrpc|WARN|unix#6: receive error: Connection reset by peer
Jul 28 22:38:09 lxdserver ovsdb-server[19827]: ovs|00016|reconnect|WARN|unix#6: connection dropped (Connection reset by peer)
Jul 28 22:40:53 lxdserver ovsdb-server[19827]: ovs|00017|jsonrpc|WARN|unix#7: receive error: Connection reset by peer
Jul 28 22:40:53 lxdserver ovsdb-server[19827]: ovs|00018|reconnect|WARN|unix#7: connection dropped (Connection reset by peer)
Instead of this, removing /var/lib/ovn and restart the ovn-central service replies another error message.
indiana@lxdserver:~$ lxc launch images:ubuntu/20.04/cloud c1 -n ovntest
Creating c1
Starting c1
Error: Failed to start device "eth0": Failed setting up OVN port: Could not find DHCPv4 options for instance port for subnet "10.202.120.0/24"
Try `lxc info --show-log local:c1` for more info
I have tested this issue at another server so ignore the ip address. But the situation is the same. Any idea and clue would be appreciated.
Humm, I found that in the lxd.log lastly.
time="2022-07-28T23:52:23+03:00" level=error msg="Failed initializing network" err="Failed starting: Failed adding OVS chassis \"8a30823a-177d-4f0f-b7ae-78bd7a0f509f\" with priority 1138 to chassis group \"lxd-net2\": Failed to run: ovn-nbctl --timeout=10 --db unix:/var/lib/snapd/hostfs/run/ovn/ovnnb_db.sock --wait=sb ha-chassis-group-add-chassis lxd-net2 8a30823a-177d-4f0f-b7ae-78bd7a0f509f 1138: 2022-07-28T20:52:23Z|00002|ovsdb_idl|WARN|NB_Global table in OVN_Northbound database lacks nb_cfg_timestamp column (database needs upgrade?)\n2022-07-28T20:52:23Z|00003|ovsdb_idl|WARN|NB_Global table in OVN_Northbound database lacks sb_cfg_timestamp column (database needs upgrade?)\novn-nbctl: lxd-net2: ha_chassi_group name not found" network=ovntest project=default
Regards.
I have corrected the ovn problem but still get the following error.
Active: active (running) since Fri 2022-07-29 00:12:43 +03; 29min ago
Main PID: 39757 (ovsdb-server)
Memory: 2.7M
└─39757 ovsdb-server -vconsole:off -vfile:info --log-file=/var/log/ovn/ovsdb-server-nb.log --remote=punix:/var/run/ovn/ovnnb_db.sock --pidfile=/var/run/ovn/ovnnb_db.pid --unixctl=/var/run/ovn/ovnnb_db.ctl --remote=db:OVN_Nor>
Jul 29 00:22:45 lxdserver ovsdb-server[39757]: ovs|00058|jsonrpc|WARN|unix#41: receive error: Connection reset by peer
Jul 29 00:22:45 lxdserver ovsdb-server[39757]: ovs|00059|reconnect|WARN|unix#41: connection dropped (Connection reset by peer)
Jul 29 00:22:45 lxdserver ovsdb-server[39757]: ovs|00060|jsonrpc|WARN|unix#49: receive error: Connection reset by peer
Jul 29 00:22:45 lxdserver ovsdb-server[39757]: ovs|00061|reconnect|WARN|unix#49: connection dropped (Connection reset by peer)
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00062|jsonrpc|WARN|unix#71: receive error: Connection reset by peer
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00063|reconnect|WARN|unix#71: connection dropped (Connection reset by peer)
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00064|jsonrpc|WARN|unix#72: receive error: Connection reset by peer
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00065|reconnect|WARN|unix#72: connection dropped (Connection reset by peer)
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00066|jsonrpc|WARN|unix#75: send error: Broken pipe
Jul 29 00:24:11 lxdserver ovsdb-server[39757]: ovs|00067|reconnect|WARN|unix#75: connection dropped (Broken pipe)
I have now get the idea of ovn a little bit
, case solved soon.
Thanks and Regards.
Actually, I have reread that thread https://discuss.linuxcontainers.org/t/cant-make-ovn-network-forward-working-in-cluster-environment/13579/5 and define the ipv{4}.routes and lxc network forward as you describe then now everything works right now. I have missed the detail before because of my lack of ovn information and lxd network.
Here are my details.
localadmin@d0051:~$ lxc network ls
| ovntest | ovn | YES | 10.10.198.1/24 | fd42:27a3:fa42:8782::1/64 | | 3 | CREATED |
localadmin@d0051:~$ lxc network show lxdbr0
ipv4.address: 10.109.131.1/24
ipv4.dhcp.ranges: 10.109.131.10-10.109.131.100
ipv4.nat: "true"
ipv4.ovn.ranges: 10.109.131.200-10.109.131.250
ipv4.routes: 10.109.131.5/32
ipv6.address: fd42:591f:483a:b70::1/64
ipv6.nat: "true"
type: bridge
- /1.0/networks/ovntest
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
localadmin@d0051:~$ lxc network forward ls ovntest
| LISTEN ADDRESS | DESCRIPTION | DEFAULT TARGET ADDRESS | PORTS |
| 10.109.131.5 | | 10.10.198.2 | 0 |
But if you are talking about that problem, NB_Global table in OVN_Northbound database lacks nb_cfg_timestamp column (database needs upgrade?) then
I overcome as I delete the ovn network and define again.
Regards.
