hi, i have to machines running lxd-containers. I upgraded one to the snap lxd installation. create a zfs-storage and copy my containers from the old to new installation to the new zfs storage with the -s copy parameter with the new zfs-pool name. The container started and ist running well for a while. Now, if I stop a container and want to run again i get this error:
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart nextcloud /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/nextcloud/lxc.conf:
And this folder ist empty, only a backup.yaml is in there.
So where is my container and rootfs? And why appears this problem after stopping the container? I have other containers migrated the same way. From old to new with new zfs storage. all are running. I tried to stop another. And the result ist the same as with the “nextcloud” container shown above.
lxc --show-info
lxc nextcloud 20200806124538.566 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.nextcloud"
lxc nextcloud 20200806124538.568 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.nextcloud"
lxc nextcloud 20200806124538.607 ERROR conf - conf.c:turn_into_dependent_mounts:3005 - Invalid argument - Failed to recursively turn old root mount tree into dependent mount. Continuing...
lxc nextcloud 20200806124538.608 ERROR dir - storage/dir.c:dir_mount:152 - No such file or directory - Failed to mount "/var/snap/lxd/common/lxd/containers/nextcloud/rootfs" on "/var/snap/lxd/common/lxc/"
lxc nextcloud 20200806124538.608 ERROR conf - conf.c:lxc_mount_rootfs:1257 - Failed to mount rootfs "/var/snap/lxd/common/lxd/containers/nextcloud/rootfs" onto "/var/snap/lxd/common/lxc/" with options "(null)"
lxc nextcloud 20200806124538.608 ERROR conf - conf.c:lxc_setup_rootfs_prepare_root:3094 - Failed to setup rootfs for
lxc nextcloud 20200806124538.608 ERROR conf - conf.c:lxc_setup:3194 - Failed to setup rootfs
lxc nextcloud 20200806124538.608 ERROR start - start.c:do_start:1224 - Failed to setup container "nextcloud"
lxc nextcloud 20200806124538.608 ERROR sync - sync.c:__sync_wait:41 - An error occurred in another process (expected sequence number 5)
lxc nextcloud 20200806124538.613 WARN network - network.c:lxc_delete_network_priv:3185 - Failed to rename interface with index 0 from "eth0" to its initial name "veth05c18771"
lxc nextcloud 20200806124538.613 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:850 - Received container state "ABORTING" instead of "RUNNING"
lxc nextcloud 20200806124538.613 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "nextcloud"
lxc nextcloud 20200806124538.614 WARN start - start.c:lxc_abort:1019 - No such process - Failed to send SIGKILL via pidfd 30 for process 3787597
lxc 20200806124538.785 WARN commands - commands.c:lxc_cmd_rsp_recv:124 - Connection reset by peer - Failed to receive response for command "get_state"
lxc nextcloud 20200806124549.376 ERROR conf - conf.c:run_buffer:324 - Script exited with status 1
lxc nextcloud 20200806124549.376 ERROR start - start.c:lxc_end:965 - Failed to run lxc.hook.post-stop for container "nextcloud"
This issue has come up a few times before and I’m struggling to resolve it.
If you remove the backup.yaml file in question your container should start. However the backup.yaml file should only be written when the ZFS volume is mounted (it isn’t at the moment which is why you cant see your container’s files).
If you can reproduce the issue reliably by stopping/starting the container we may be able to figure this one out more thoroughly.
I got the same error and the backup.yaml is newly created.
lxc info --show-log plsrv2:nextcloud
Remote: https://192.168.20.108:8443
Created: 2020/07/28 20:48 UTC
Status: Stopped
Type: container
Profiles: zfs-bridged
Log:
lxc nextcloud 20200806170908.309 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.nextcloud"
lxc nextcloud 20200806170908.323 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.nextcloud"
lxc nextcloud 20200806170908.559 ERROR conf - conf.c:turn_into_dependent_mounts:3005 - Invalid argument - Failed to recursively turn old root mount tree into dependent mount. Continuing...
lxc nextcloud 20200806170908.560 ERROR conf - conf.c:turn_into_dependent_mounts:3005 - Invalid argument - Failed to recursively turn old root mount tree into dependent mount. Continuing...
lxc nextcloud 20200806170908.561 ERROR conf - conf.c:turn_into_dependent_mounts:3005 - Invalid argument - Failed to recursively turn old root mount tree into dependent mount. Continuing...
lxc nextcloud 20200806170908.561 ERROR dir - storage/dir.c:dir_mount:152 - No such file or directory - Failed to mount "/var/snap/lxd/common/lxd/containers/nextcloud/rootfs" on "/var/snap/lxd/common/lxc/"
lxc nextcloud 20200806170908.561 ERROR conf - conf.c:lxc_mount_rootfs:1257 - Failed to mount rootfs "/var/snap/lxd/common/lxd/containers/nextcloud/rootfs" onto "/var/snap/lxd/common/lxc/" with options "(null)"
lxc nextcloud 20200806170908.561 ERROR conf - conf.c:lxc_setup_rootfs_prepare_root:3094 - Failed to setup rootfs for
lxc nextcloud 20200806170908.561 ERROR conf - conf.c:lxc_setup:3194 - Failed to setup rootfs
lxc nextcloud 20200806170908.561 ERROR start - start.c:do_start:1224 - Failed to setup container "nextcloud"
lxc nextcloud 20200806170908.563 ERROR sync - sync.c:__sync_wait:41 - An error occurred in another process (expected sequence number 5)
lxc nextcloud 20200806170908.615 WARN network - network.c:lxc_delete_network_priv:3185 - Failed to rename interface with index 0 from "eth0" to its initial name "veth99f77889"
lxc nextcloud 20200806170908.616 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:850 - Received container state "ABORTING" instead of "RUNNING"
lxc nextcloud 20200806170908.616 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "nextcloud"
lxc nextcloud 20200806170908.616 WARN start - start.c:lxc_abort:1019 - No such process - Failed to send SIGKILL via pidfd 30 for process 263395
lxc 20200806170908.221 WARN commands - commands.c:lxc_cmd_rsp_recv:124 - Connection reset by peer - Failed to receive response for command "get_state"
lxc nextcloud 20200806170918.789 ERROR conf - conf.c:run_buffer:324 - Script exited with status 1
lxc nextcloud 20200806170918.790 ERROR start - start.c:lxc_end:965 - Failed to run lxc.hook.post-stop for container "nextcloud"
Was this a problem with the zfs system? I migrated to zfs because I have sevaral problems with btrfs, so I though give zfs a try, but I think the safest way would be to move back to completly “normal” filesystems for my containers.
I suspect its some sort of race condition in the lxd mounting code that is unmounting the volume whilst LXD is writing the backup file, thats why it rarely comes up.
Is that output you posted from /var/snap/lxd/common/lxd/logs/lxd.log or from lxc info --show-log, as the former would be more useful for debugging this issue.
Now, the next container wouldn’t restart. Even after set to debug and reloading the deamon.
I have made a snapshot of the container and run an reboot in the container. After that, the “backup.yml” File ist there and the container doesn’t start. Then I set the log to debug (as in previous posts); reload the deamon, tests it. No Start. Set debug to false. reload deamon. Start. Doesn’t start.
Output Log is:
lxc info --show-log plsrv2:nodered
Created: 2020/07/28 19:15 UTC
Status: Stopped
Type: container
Log:
lxc nodered 20200820083904.739 TRACE commands - commands.c:lxc_cmd:290 - Connection refused - Command "get_state" failed to connect command socket
lxc nodered 20200820083904.739 TRACE start - start.c:lxc_init_handler:694 - Created anonymous pair {3,7} of unix sockets
lxc nodered 20200820083904.739 TRACE commands - commands.c:lxc_cmd_init:1671 - Created abstract unix socket "/var/snap/lxd/common/lxd/containers/nodered/command"
lxc nodered 20200820083904.739 TRACE start - start.c:lxc_init_handler:709 - Unix domain socket 9 for command server is ready
lxc nodered 20200820083904.739 INFO lxccontainer - lxccontainer.c:do_lxcapi_start:969 - Set process title to [lxc monitor] /var/snap/lxd/common/lxd/containers nodered
lxc nodered 20200820083904.740 DEBUG lxccontainer - lxccontainer.c:wait_on_daemonized_start:830 - First child 2774604 exited
lxc nodered 20200820083904.740 INFO start - start.c:lxc_check_inherited:286 - Closed inherited fd 4
lxc nodered 20200820083904.740 INFO start - start.c:lxc_check_inherited:286 - Closed inherited fd 5
lxc nodered 20200820083904.740 INFO start - start.c:lxc_check_inherited:286 - Closed inherited fd 6
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_start:2113 - Doing lxc_start
lxc nodered 20200820083904.740 INFO lsm - lsm/lsm.c:lsm_init:30 - LSM security driver AppArmor
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_init:732 - Initialized LSM
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_serve_state_clients:438 - Set container state to STARTING
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_serve_state_clients:441 - No state clients registered
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_init:738 - Set container state to "STARTING"
lxc nodered 20200820083904.740 TRACE start - start.c:lxc_init:794 - Set environment variables
lxc nodered 20200820083904.740 INFO conf - conf.c:run_script_argv:343 - Executing script "/proc/2773932/exe callhook /var/snap/lxd/common/lxd 326 start" for container "nodered"
lxc nodered 20200820083904.740 TRACE conf - conf.c:run_script_argv:386 - Set environment variable: LXC_HOOK_TYPE=pre-start
lxc nodered 20200820083904.740 TRACE conf - conf.c:run_script_argv:391 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc nodered 20200820083904.822 TRACE start - start.c:lxc_init:799 - Ran pre-start hooks
lxc nodered 20200820083904.822 TRACE start - start.c:setup_signal_fd:331 - Created signal file descriptor 5
lxc nodered 20200820083904.822 TRACE start - start.c:lxc_init:808 - Set up signal fd
lxc nodered 20200820083904.823 DEBUG terminal - terminal.c:lxc_terminal_peer_default:655 - No such device - The process does not have a controlling terminal
lxc nodered 20200820083904.823 DEBUG terminal - terminal.c:lxc_terminal_create_log_file:827 - Using "/var/snap/lxd/common/lxd/logs/nodered/console.log" as terminal log file
lxc nodered 20200820083904.823 TRACE terminal - terminal.c:lxc_terminal_create_ringbuf:808 - Allocated 131072 byte terminal ringbuffer
lxc nodered 20200820083904.823 TRACE start - start.c:lxc_init:816 - Created console
lxc nodered 20200820083904.823 TRACE conf - conf.c:userns_exec_mapped_root:4428 - Chowned 10(/dev/pts/11) to uid 1000000 and 1000000
lxc nodered 20200820083904.823 TRACE terminal - terminal.c:lxc_terminal_map_ids:1176 - Chowned terminal 10(/dev/pts/11)
lxc nodered 20200820083904.823 TRACE start - start.c:lxc_init:823 - Chowned console
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:941 - basecginfo is:
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:942 - 12:rdma:/
11:perf_event:/
10:blkio:/init.scope
9:devices:/init.scope
8:freezer:/
7:hugetlb:/
6:cpu,cpuacct:/init.scope
5:pids:/init.scope
4:net_cls,net_prio:/
3:cpuset:/
2:memory:/init.scope
1:name=systemd:/init.scope
0::/init.scope
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 0: rdma
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 1: perf_event
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 2: blkio
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 3: devices
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 4: freezer
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 5: hugetlb
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 6: cpu
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 7: cpuacct
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 8: pids
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 9: net_cls
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 10: net_prio
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 11: cpuset
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 12: memory
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:945 - kernel subsystem 13: cgroup2
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:948 - named subsystem 0: name=systemd
lxc nodered 20200820083904.823 TRACE cgfsng - cgroups/cgfsng.c:cg_hybrid_init:3261 - No controllers are enabled for delegation in the unified hierarchy
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:cg_hybrid_init:3279 - Writable cgroup hierarchies:
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:922 - Hierarchies:
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 0: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/unified
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:929 - controllers:
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 1: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/systemd
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: name=systemd
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 2: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/memory
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: memory
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 3: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/cpuset
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: cpuset
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 4: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/net_cls,net_prio
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: net_cls
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 1: net_prio
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 5: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/pids
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: pids
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 6: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/cpu,cpuacct
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 1: cpuacct
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 7: base_cgroup: /
lxc nodered 20200820083904.825 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/hugetlb
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:929 - controllers:
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: hugetlb
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 8: base_cgroup: /
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/freezer
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: freezer
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 9: base_cgroup: /
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/devices
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: devices
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 10: base_cgroup: /
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/blkio
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: blkio
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 11: base_cgroup: /
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/perf_event
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: perf_event
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:927 - 12: base_cgroup: /
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:928 - mountpoint: /sys/fs/cgroup/rdma
lxc nodered 20200820083904.826 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:931 - 0: rdma
lxc nodered 20200820083904.826 TRACE cgroup - cgroups/cgroup.c:cgroup_init:41 - Initialized cgroup driver cgfsng
lxc nodered 20200820083904.826 TRACE cgroup - cgroups/cgroup.c:cgroup_init:46 - Running with hybrid cgroup layout
lxc nodered 20200820083904.826 TRACE start - start.c:lxc_init:830 - Initialized cgroup driver
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:get_new_ctx:470 - Added arch 2 to main seccomp context
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:get_new_ctx:478 - Removed native arch from main seccomp context
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:get_new_ctx:470 - Added arch 3 to main seccomp context
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:get_new_ctx:483 - Arch 4 already present in main seccomp context
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "[all]"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "reject_force_umount # comment this to allow umount -f; not recommended"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:do_resolve_add_rule:517 - Set seccomp rule to reject force umounts
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for reject_force_umount action 0(kill)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for reject_force_umount action 0(kill)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for reject_force_umount action 0(kill)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for reject_force_umount action 0(kill)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "kexec_load errno 38"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for kexec_load action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for kexec_load action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for kexec_load action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for kexec_load action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "open_by_handle_at errno 38"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for open_by_handle_at action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for open_by_handle_at action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for open_by_handle_at action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for open_by_handle_at action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "init_module errno 38"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for init_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for init_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for init_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for init_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "finit_module errno 38"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for finit_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for finit_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for finit_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for finit_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:790 - Processing "delete_module errno 38"
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:987 - Added native rule for arch 0 for delete_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:996 - Added compat rule for arch 1073741827 for delete_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1006 - Added compat rule for arch 1073741886 for delete_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1016 - Added native rule for arch -1073741762 for delete_module action 327718(errno)
lxc nodered 20200820083904.826 INFO seccomp - seccomp.c:parse_config_v2:1020 - Merging compat seccomp contexts into main context
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:parse_config_v2:1030 - Merged first compat seccomp context into main context
lxc nodered 20200820083904.826 TRACE seccomp - seccomp.c:parse_config_v2:1046 - Merged second compat seccomp context into main context
lxc nodered 20200820083904.826 TRACE start - start.c:lxc_init:835 - Read seccomp policy
lxc nodered 20200820083904.826 TRACE start - start.c:lxc_init:842 - Initialized LSM
lxc nodered 20200820083904.826 INFO start - start.c:lxc_init:844 - Container "nodered" is initialized
lxc nodered 20200820083904.842 TRACE cgfsng - cgroups/cgfsng.c:cg_legacy_handle_cpuset_hierarchy:552 - "cgroup.clone_children" was already set to "1"
lxc nodered 20200820083904.843 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.nodered"
lxc nodered 20200820083904.843 INFO cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1368 - The monitor process uses "lxc.monitor.nodered" as cgroup
lxc nodered 20200820083904.844 DEBUG storage - storage/storage.c:get_storage_by_name:211 - Detected rootfs type "dir"
lxc nodered 20200820083904.844 TRACE cgfsng - cgroups/cgfsng.c:cg_legacy_handle_cpuset_hierarchy:552 - "cgroup.clone_children" was already set to "1"
lxc nodered 20200820083904.844 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.nodered"
lxc nodered 20200820083904.844 INFO cgfsng - cgroups/cgfsng.c:cgfsng_payload_create:1471 - The container process uses "lxc.payload.nodered" as cgroup
lxc nodered 20200820083904.844 TRACE start - start.c:lxc_spawn:1658 - Argument list too long - Failed to spawn container directly into target cgroup
lxc nodered 20200820083904.846 TRACE start - start.c:lxc_spawn:1690 - Cloned child process 2774651
lxc nodered 20200820083904.846 TRACE utils - utils.c:lxc_can_use_pidfd:1861 - Kernel supports pidfds
lxc nodered 20200820083904.846 INFO start - start.c:lxc_spawn:1706 - Cloned CLONE_NEWUSER
lxc nodered 20200820083904.846 INFO start - start.c:lxc_spawn:1706 - Cloned CLONE_NEWNS
lxc nodered 20200820083904.846 INFO start - start.c:lxc_spawn:1706 - Cloned CLONE_NEWPID
lxc nodered 20200820083904.846 INFO start - start.c:lxc_spawn:1706 - Cloned CLONE_NEWUTS
lxc nodered 20200820083904.847 INFO start - start.c:lxc_spawn:1706 - Cloned CLONE_NEWIPC
lxc nodered 20200820083904.847 DEBUG start - start.c:lxc_try_preserve_namespaces:167 - Preserved user namespace via fd 31
lxc nodered 20200820083904.847 DEBUG start - start.c:lxc_try_preserve_namespaces:167 - Preserved mnt namespace via fd 32
lxc nodered 20200820083904.847 DEBUG start - start.c:lxc_try_preserve_namespaces:167 - Preserved pid namespace via fd 33
lxc nodered 20200820083904.847 DEBUG start - start.c:lxc_try_preserve_namespaces:167 - Preserved uts namespace via fd 34
lxc nodered 20200820083904.847 DEBUG start - start.c:lxc_try_preserve_namespaces:167 - Preserved ipc namespace via fd 35
lxc nodered 20200820083904.847 DEBUG conf - conf.c:lxc_map_ids:2757 - No newuidmap and newgidmap binary found. Trying to write directly with euid 0
lxc nodered 20200820083904.847 TRACE conf - conf.c:lxc_map_ids:2823 - Wrote mapping "0 1000000 1000000000
lxc nodered 20200820083904.848 INFO start - start.c:do_start:1091 - Unshared CLONE_NEWNET
lxc nodered 20200820083904.848 TRACE conf - conf.c:get_minimal_idmap:3950 - Allocated minimal idmapping for ns uid 0 and ns gid 0
lxc nodered 20200820083904.849 TRACE conf - conf.c:userns_exec_1:4016 - Establishing uid mapping for "2774652" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc nodered 20200820083904.849 TRACE conf - conf.c:userns_exec_1:4016 - Establishing uid mapping for "2774652" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc nodered 20200820083904.849 TRACE conf - conf.c:userns_exec_1:4016 - Establishing gid mapping for "2774652" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc nodered 20200820083904.849 TRACE conf - conf.c:userns_exec_1:4016 - Establishing gid mapping for "2774652" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc nodered 20200820083904.849 DEBUG conf - conf.c:lxc_map_ids:2757 - No newuidmap and newgidmap binary found. Trying to write directly with euid 0
lxc nodered 20200820083904.849 TRACE conf - conf.c:lxc_map_ids:2823 - Wrote mapping "1000000000 0 1
lxc nodered 20200820083904.849 TRACE conf - conf.c:run_userns_fn:3792 - Calling function "chown_cgroup_wrapper"
lxc nodered 20200820083904.849 NOTICE utils - utils.c:lxc_setgroups:1366 - Dropped additional groups
lxc nodered 20200820083904.849 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1573 - No such file or directory - Failed to fchownat(17, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
lxc nodered 20200820083904.852 DEBUG start - start.c:lxc_spawn:1779 - Preserved net namespace via fd 4
lxc nodered 20200820083904.852 TRACE start - start.c:lxc_spawn:1786 - Allocated new network namespace id
lxc nodered 20200820083904.852 DEBUG network - network.c:instantiate_phys:821 - Instantiated phys "veth1f9b6958" with ifindex is "192"
lxc nodered 20200820083904.895 DEBUG network - network.c:lxc_network_move_created_netdev_priv:3104 - Moved network device "veth1f9b6958" with ifindex 192 to network namespace of 2774651
lxc nodered 20200820083904.895 TRACE network - network.c:lxc_network_send_to_child:3558 - Sent network device name "veth1f9b6958" to child
lxc nodered 20200820083904.895 TRACE network - network.c:lxc_network_recv_from_parent:3585 - Received network device name "veth1f9b6958" from parent
lxc nodered 20200820083904.895 NOTICE utils - utils.c:lxc_setgroups:1366 - Dropped additional groups
lxc nodered 20200820083904.895 NOTICE utils - utils.c:lxc_switch_uid_gid:1344 - Switched to gid 0
lxc nodered 20200820083904.895 NOTICE utils - utils.c:lxc_switch_uid_gid:1353 - Switched to uid 0
lxc nodered 20200820083904.895 INFO start - start.c:do_start:1204 - Unshared CLONE_NEWCGROUP
lxc nodered 20200820083904.898 TRACE conf - conf.c:turn_into_dependent_mounts:3010 - Turned all mount table entries into dependent mount
lxc nodered 20200820083904.898 DEBUG storage - storage/storage.c:get_storage_by_name:211 - Detected rootfs type "dir"
lxc nodered 20200820083904.898 ERROR dir - storage/dir.c:dir_mount:152 - No such file or directory - Failed to mount "/var/snap/lxd/common/lxd/containers/nodered/rootfs" on "/var/snap/lxd/common/lxc/"
lxc nodered 20200820083904.899 ERROR conf - conf.c:lxc_mount_rootfs:1257 - Failed to mount rootfs "/var/snap/lxd/common/lxd/containers/nodered/rootfs" onto "/var/snap/lxd/common/lxc/" with options "(null)"
lxc nodered 20200820083904.899 ERROR conf - conf.c:lxc_setup_rootfs_prepare_root:3094 - Failed to setup rootfs for
lxc nodered 20200820083904.899 ERROR conf - conf.c:lxc_setup:3194 - Failed to setup rootfs
lxc nodered 20200820083904.899 ERROR start - start.c:do_start:1224 - Failed to setup container "nodered"
lxc nodered 20200820083904.899 ERROR sync - sync.c:__sync_wait:41 - An error occurred in another process (expected sequence number 5)
lxc nodered 20200820083904.903 WARN network - network.c:lxc_delete_network_priv:3185 - Failed to rename interface with index 0 from "eth0" to its initial name "veth1f9b6958"
lxc nodered 20200820083904.904 DEBUG network - network.c:lxc_delete_network:3665 - Deleted network devices
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_serve_state_socket_pair:503 - Sent container state "ABORTING" to 7
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_serve_state_clients:438 - Set container state to ABORTING
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_serve_state_clients:441 - No state clients registered
lxc nodered 20200820083904.904 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:850 - Received container state "ABORTING" instead of "RUNNING"
lxc nodered 20200820083904.904 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "nodered"
lxc nodered 20200820083904.904 WARN start - start.c:lxc_abort:1019 - No such process - Failed to send SIGKILL via pidfd 30 for process 2774651
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_serve_state_clients:438 - Set container state to STOPPING
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_USER_NS=/proc/2774605/fd/31
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_MNT_NS=/proc/2774605/fd/32
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_PID_NS=/proc/2774605/fd/33
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_UTS_NS=/proc/2774605/fd/34
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_IPC_NS=/proc/2774605/fd/35
lxc nodered 20200820083904.904 TRACE start - start.c:lxc_end:900 - Set environment variable LXC_NET_NS=/proc/2774605/fd/4
lxc nodered 20200820083904.904 INFO conf - conf.c:run_script_argv:343 - Executing script "/snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 326 stopns" for container "nodered"
lxc nodered 20200820083904.904 TRACE conf - conf.c:run_script_argv:386 - Set environment variable: LXC_HOOK_TYPE=stop
lxc nodered 20200820083904.904 TRACE conf - conf.c:run_script_argv:391 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc nodered 20200820083905.231 TRACE conf - conf.c:get_minimal_idmap:3950 - Allocated minimal idmapping for ns uid 0 and ns gid 0
lxc nodered 20200820083905.238 TRACE conf - conf.c:userns_exec_1:4016 - Establishing uid mapping for "2774676" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc nodered 20200820083905.238 TRACE conf - conf.c:userns_exec_1:4016 - Establishing uid mapping for "2774676" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc nodered 20200820083905.238 TRACE conf - conf.c:userns_exec_1:4016 - Establishing gid mapping for "2774676" in new user namespace: nsuid 1000000000 - hostid 0 - range 1
lxc nodered 20200820083905.238 TRACE conf - conf.c:userns_exec_1:4016 - Establishing gid mapping for "2774676" in new user namespace: nsuid 0 - hostid 1000000 - range 1000000000
lxc nodered 20200820083905.239 DEBUG conf - conf.c:lxc_map_ids:2757 - No newuidmap and newgidmap binary found. Trying to write directly with euid 0
lxc nodered 20200820083905.240 TRACE conf - conf.c:lxc_map_ids:2823 - Wrote mapping "1000000000 0 1
lxc nodered 20200820083905.241 TRACE conf - conf.c:run_userns_fn:3792 - Calling function "cgroup_tree_remove_wrapper"
lxc nodered 20200820083905.243 NOTICE utils - utils.c:lxc_setgroups:1366 - Dropped additional groups
lxc nodered 20200820083905.270 TRACE cgfsng - cgroups/cgfsng.c:cg_legacy_handle_cpuset_hierarchy:552 - "cgroup.clone_children" was already set to "1"
lxc nodered 20200820083905.537 TRACE start - start.c:lxc_end:943 - Closed command socket
lxc 20200820083905.538 WARN commands - commands.c:lxc_cmd_rsp_recv:124 - Connection reset by peer - Failed to receive response for command "get_state"
lxc nodered 20200820083905.538 TRACE start - start.c:lxc_end:954 - Set container state to "STOPPED"
lxc 20200820083905.538 TRACE commands - commands.c:lxc_cmd:298 - Opened new command socket connection fd 50 for command "get_state"
lxc nodered 20200820083905.790 INFO conf - conf.c:run_script_argv:343 - Executing script "/snap/lxd/current/lxcfs/lxc.reboot.hook" for container "nodered"
lxc nodered 20200820083905.791 TRACE conf - conf.c:run_script_argv:386 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc nodered 20200820083905.791 TRACE conf - conf.c:run_script_argv:391 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc nodered 20200820083905.582 INFO conf - conf.c:run_script_argv:343 - Executing script "/snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 326 stop" for container "nodered"
lxc nodered 20200820083905.582 TRACE conf - conf.c:run_script_argv:386 - Set environment variable: LXC_HOOK_TYPE=post-stop
lxc nodered 20200820083905.582 TRACE conf - conf.c:run_script_argv:391 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc nodered 20200820083915.624 DEBUG conf - conf.c:run_buffer:313 - Script exec /snap/lxd/current/bin/lxd callhook /var/snap/lxd/common/lxd 326 stop produced output: Error: Failed to unmount '/var/snap/lxd/common/lxd/storage-pools/zfs-pool1/containers/nodered': invalid argument
lxc nodered 20200820083915.627 ERROR conf - conf.c:run_buffer:324 - Script exited with status 1
lxc nodered 20200820083915.627 ERROR start - start.c:lxc_end:965 - Failed to run lxc.hook.post-stop for container "nodered"
lxc 20200820083922.570 TRACE commands - commands.c:lxc_cmd:290 - Connection refused - Command "get_state" failed to connect command socket
lxc 20200820083922.627 TRACE commands - commands.c:lxc_cmd:290 - Connection refused - Command "get_state" failed to connect command socket
lxc 20200820083922.628 TRACE commands - commands.c:lxc_cmd:290 - Connection refused - Command "get_state" failed to connect command socket
unfortunately no. I set deamon to debug. restart deamon. remove backup.yml. start the container.
Get this error (and log from above):
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart nodered /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/nodered/lxc.conf:
Try `lxc info --show-log plsrv2:nodered` for more info
Than I set debug back to false. reload deamon. remove backup.yml. try to start again. No Start of the container (error as above)
On further investigation on the affected system the issue appeared to be a kernel issue with dmesg logging multiple I/O subsystem crashes mentioning clearing mounts.
The LXD snap mount namespace showed hundreds of mounts and the affected container had at least 20 mounts for the same directory. However they couldn’t be unmounted using umount or zfs unmount.
Have suggested a reboot to see if that fixes the issue.
@stgraber have you seen anything like that before?
i shutdown all containers (exec into container and shutdown command). restartet the system and then I could start the container without issues…
I think about to move the cotainers away from zfs-storage to plain file storage.
@tomp
Thanks again for immediately examining the issue!
Same problem here.
Old LXC container migrated to LXD (copy of rootfs over a small LXD container), then container moved to another host (copy of a snapshot)
When I start container, only boot init process is created.
$ lxc info --show-log suivi
Remote: unix://
Created: 2021/02/19 19:24 UTC
Status: Stopped
Type: container
Profiles: lanprofile
Log:
lxc suivi 20210219205847.837 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1126 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.suivi"
lxc suivi 20210219205847.842 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1126 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.suivi"
lxc suivi 20210219205847.886 ERROR conf - conf.c:turn_into_dependent_mounts:3065 - No such file or directory - Failed to recursively turn old root mount tree into dependent mount. Continuing...
lxc suivi 20210219205847.914 ERROR utils - utils.c:__safe_mount_beneath_at:1106 - Function not implemented - Failed to open 30(dev)
lxc suivi 20210219205945.456 WARN cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:1083 - Success - Failed to initialize cpuset /sys/fs/cgroup/cpuset//lxc.pivot/lxc.pivot
I don’t understand how you resolve the previous case, can you explain me please ?
I tried to mount zfs pool, delete backup.yaml, restart container, reboot host, nothing works
After all, we didn’t solve the issue. I shutdown all containers, restart the host. Then the container with the problem was starting right and I use this state to move the container back from zfs storage to a non journaling filesystem with ext4. Till than it worked well. I think it was an issue with the zfs - storage or probably the HDD it self.
strange because I do this migration with 2 containers, first one no problem (but it’s not a container migrated from LXC), second can’t make it boot
