Host: Ubuntu 20.04
Incus 0.1
zfs storage pool
Steps to reproduce:
incus launch images:ubuntu/jammy jammy1
incus stop --force jammy1
takes forever, ipv4 vanishes from list, but still shows as ‘RUNNING’
incus info --show-log jammy1
Status: RUNNING
Type: container
PID: 291865
Created: 2023/10/25 12:31 CEST
Last Used: 2023/10/25 12:32 CESTResources:
Processes: 1
Disk usage:
root: 3.49MiB
CPU usage:
CPU usage (in seconds): 3
Memory usage:
Memory (current): 48.13MiB
Memory (peak): 77.12MiBLog:
lxc jammy1 20231025103204.136 WARN conf - …/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc jammy1 20231025103204.136 WARN conf - …/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc jammy1 20231025103204.138 WARN conf - …/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc jammy1 20231025103204.138 WARN conf - …/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc jammy1 20231025103204.139 WARN cgfsng - …/src/lxc/cgroups/cgfsng.c:fchowmodat:1619 - No such file or directory - Failed to fchownat(40, memory.oom.group, 65536, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
lxc jammy1 20231025103204.325 WARN mainloop - …/src/lxc/mainloop.c:__lxc_mainloop_io_uring:290 - Received unexpected return value -95 in cqe for “signal_handler” handler
lxc jammy1 20231025103204.325 WARN mainloop - …/src/lxc/mainloop.c:__lxc_mainloop_io_uring:290 - Received unexpected return value -22 in cqe for “lxc_terminal_ptx_io_handler” handler
incus config show jammy1 --expanded
image.architecture: amd64
image.description: Ubuntu jammy amd64 (20231024_07:42)
image.os: Ubuntu
image.release: jammy
image.serial: “20231024_07:42”
image.type: squashfs
image.variant: default
volatile.base_image: a65818d75b6d83703084aeda3e8f1e5e4d820f343583d6a8e24844433956bf02
volatile.cloud-init.instance-id: db241416-91a7-47de-95cf-dead15e8c4ba
volatile.eth0.host_name: veth7dac77cc
volatile.eth0.hwaddr: 00:16:3e:89:87:a1
volatile.idmap.base: “0”
volatile.idmap.current: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536}]’
volatile.idmap.next: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536}]’
volatile.last_state.idmap: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:65536}]’
volatile.uuid: 3a90561b-71b7-46fa-ac84-d926a0869f80
volatile.uuid.generation: 3a90561b-71b7-46fa-ac84-d926a0869f80
nictype: bridged
parent: lxdbr0
pool: pl
description: “”
Appreciate any help or hint what to look for.
