Container /dev entry not updating on usb device reconnect
I am trying to connect a usb scanner to a container (Incus 6.9 on debian 12). When I start the container all is well
  s1500:
    productid: 11a2
    type: usb
    vendorid: 04c5
## host
# lsusb
Bus 003 Device 010: ID 04c5:11a2 Fujitsu, Ltd ScanSnap S1500
# ls -l /dev/bus/usb/003/010
crw-rw-r-- 1 root root 189, 265 Feb  2 00:02 /dev/bus/usb/003/010
## container
# lsusb
crw-rw-r-- 1 root root 189, 265 Feb  2 08:11 /dev/bus/usb/003/010
The device can be accessed from the container.
If the scanner shuts down and reconnects, though, I am no longer able to access it from the container. The device number updates and this is reflected by lsusb on host and container. The udev entry on the host is also updated but the container keeps the stale device entry.
## host
crw-rw-r-- 1 root root 189, 266 Feb  2 00:23 011
## container
crw-rw-r-- 1 root root 189, 265 Feb  2 08:11 010
Is there some way to get the /dev entry in the container to update when the usb device is reconnected?
Thanks
Solved - after changing the device type from usb to unix-hotplug all is well
