I have an incus bridge incusbr0 with a dnsmasq configured to run on port 5353 using:
raw.dnsmasq: port=5353
My problem is the resolver configuration inside containers doesn’t receives the port from the dhcp.
For the moment I do it manually by launching
resolvectl dns eth0 [ipv6address]:5353
But obviously it doesn’t survive any reboot ![]()
I tried to specifying a name server with the syntax ipv4:port and/or [ipv6]:port into dns.nameservers but it seems that property expects only an IP address.
Does a mechanism to workaround that situation exists ?
Thanks in advance
