The mission
I’m trying to migrate my GitLab deployment (Docker on a VM) to an Incus container by following the instructions at Frequently asked questions - Incus documentation to setup Docker on an Incus container, and I’m stuck.
What I’ve done so far
I have created a fresh Debian 12 container with two network bridges connected to it: eth0=lan0 and eth1=lan0-proxy. Its network config:
$ cat /etc/systemd/network/eth0.network
[Match]
Name=eth0
[Network]
LinkLocalAddressing=ipv4
DHCP=ipv4
[DHCPv4]
UseDomains=true
[DHCP]
ClientIdentifier=mac
$ cat /etc/systemd/network/eth1.network
[Match]
Name=eth1
[Network]
Address=10.127.0.10/16
My networking setup in a nutshell
For context, I’m running a separate Incus container for DHCP/DNS at 10.0.0.2 with Technitium DNS (Technitium DNS Server | An Open Source DNS Server For Privacy & Security) on the lan0 bridge, so eth0 gets an IP from that container. lan0-proxy is just an internal bridge to play around with, I’ve set an arbitrary IP address on it with no gateway, as lan0-proxy itself doesn’t have an IP address either. I also have pfSense setup which acts as default gateway for instances on lan0 at 10.0.0.3.
To nest or not to nest
With security.nesting=false, the container’s networking is the following:
$ ip a
43: eth0@if44: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 10:66:6a:27:47:3c brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.1.3/16 metric 1024 brd 10.0.255.255 scope global dynamic eth0
valid_lft 59sec preferred_lft 59sec
45: eth1@if46: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 10:66:6a:bc:a0:79 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.127.0.10/16 brd 10.127.255.255 scope global eth1
$ journalctl -xeu systemd-networkd
Apr 05 01:40:21 005-registry-infra systemd[1]: Starting systemd-networkd.service - Network Configuration...
Subject: A start job for unit systemd-networkd.service has begun execution
Defined-By: systemd
Support: https://www.debian.org/support
A start job for unit systemd-networkd.service has begun execution.
The job identifier is 77.
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: Failed to increase receive buffer size for general netlink socket, ignoring: Operation not permitted
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth1: Link UP
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth1: Gained carrier
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth1: Configuring with /etc/systemd/network/eth1.network.
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth0: Link UP
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth0: Gained carrier
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth0: Configuring with /etc/systemd/network/eth0.network.
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: lo: Link UP
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: lo: Gained carrier
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: Enumeration completed
Apr 05 01:40:21 005-registry-infra systemd[1]: Started systemd-networkd.service - Network Configuration.
Subject: A start job for unit systemd-networkd.service has finished successfully
Defined-By: systemd
A start job for unit systemd-networkd.service has finished successfully.
Apr 05 01:40:21 005-registry-infra systemd-networkd[147]: eth0: DHCPv4 address 10.0.1.3/16, gateway 10.0.0.3 acquired from 10.0.0.2
However, setting security.nesting=true results in this:
$ ip a
47: eth0@if48: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
49: eth1@if50: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
$ journalctl -xeu systemd-networkd --no-pager
Apr 05 01:43:01 005-registry-infra systemd[1]: Starting systemd-networkd.service - Network Configuration...
Defined-By: systemd
The job identifier is 83.
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: Failed to increase receive buffer size for general netlink socket, ignoring: Operation not permitted
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: eth1: Link UP
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: eth1: Gained carrier
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: eth0: Link UP
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: eth0: Gained carrier
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: lo: Link UP
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: lo: Gained carrier
Apr 05 01:43:02 005-registry-infra systemd-networkd[144]: Enumeration completed
Apr 05 01:43:02 005-registry-infra systemd[1]: Started systemd-networkd.service - Network Configuration.
Defined-By: systemd
I also disabled IPv6 completely on the Incus host by setting the kernel cmdline parameter ipv6.disable=1 because 1) I’m not familiar with it and 2) I wanted to make sure that IPv6 isn’t causing the situation. And it isn’t causing it, so that’s good to know. (btw. with IPv6 enabled, running ip a in the nesting-enabled container shows an additional inet6 line and nothing more of particular interest).
OS & Incus details
$ incus version
Client version: 6.11
Server version: 6.11
$ cat /etc/apt/sources.list.d/zabbly-incus-stable.sources
Enabled: yes
Types: deb
URIs: https://pkgs.zabbly.com/incus/stable
Suites: bookworm
Components: main
Architectures: amd64
Signed-By: /etc/apt/keyrings/zabbly.asc
cat /etc/apt/sources.list.d/zabbly-kernel-stable.sources
Enabled: yes
Types: deb deb-src
URIs: https://pkgs.zabbly.com/kernel/stable
Suites: bookworm
Components: main zfs
$ uname -a
Linux incus.thetre.dev 6.13.9-zabbly+ #debian12 SMP PREEMPT_DYNAMIC Mon Mar 31 02:08:07 UTC 2025 x86_64 GNU/Linux
$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
$ incus network list
incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| enp7s0 | physical | NO | | | | 1 | |
| lan0 | bridge | YES | 10.0.0.1/16 | none | | 10 | CREATED |
| lan0-proxy | bridge | YES | none | none | | 6 | CREATED |
| lo | loopback | NO | | | | 0 | |
$ incus network show lan0
ipv4.address: 10.0.0.1/16
ipv4.dhcp: "false"
ipv4.firewall: "false"
ipv4.nat: "true"
ipv6.address: none
[REDACTED]
$ incus network show lan0-proxy
ipv4.address: none
ipv4.dhcp: "false"
ipv4.nat: "true"
ipv6.address: none
[REDACTED]
What to do next?
The DHCP/DNS/pfSense setup can’t be the reason because if that were the case then only eth0 would behave weird, while eth1 would still have the static IP address set by systemd-networkd which has nothing to do with either of those deployments - lan0-proxy is completely separated from anything else.
Is there any way I can debug any further? Thanks!
