The situation is:
- I created a container with shiftfs already being enabled - everything worked fine for months now, until:
- For some reason sometimes during kernel updates the builds of dkms modules fail (reasons not important here), including the one for shiftfs (without telling me; arch linux problem
). - LXD then disables shiftfs (also without telling me), because it can’t find the module.
- When I start the container, LXD automatically tries to “remap” the container (it says “remapping”).
- It fails.
Now even after I re-enable shiftfs, the regular container start does not work anymore.
Errors reported were:
Error: Error occurred when starting proxy device: Error: remove /mnt/wayland1/wayland-0: permission deniedError: Error occurred when starting proxy device: Error: Failed to receive fd from listener process
Container Log shows:
lxc gaming1 20200823144555.732 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - file already exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.gaming1"
lxc gaming1 20200823144555.734 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - file already exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.gaming1"
lxc gaming1 20200823144555.754 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1570 - file or folder not found - Failed to fchownat(17, memory.oom.group, 65536, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
Note: file already exists & file or folder not found are my translations.
Solutions I tried:
- Computer restart
- setting
security.privileged trueand unset it again, to apply shiftfs ones again.
Interestingly the container starts fine with security.privileged true.
But fails when I unset security.privileged.
I will probably try to remove all profiles with the proxy devices and apply them again.
Regarding general behaviour of LXD:
I would like LXD to warn and ask me before disabling shiftfs and remapping my container.
Additional information:
Other containers start well, but they did not get remapped (were not started during shiftfs=false) and most of them don’t have proxy devices or disk devices with shiftfs.
Container config:
image.architecture: x86_64
image.description: Archlinux x86_64 (20200723_1910)
image.name: archlinux--x86_64-default-20200723_1910
image.os: archlinux
image.serial: "20200723_1910"
image.variant: default
security.idmap.isolated: "true"
volatile.base_image: 68bb944fc0055f0d07dc18cfc513ca011356095cd68000b8fbf61e44d769553e
volatile.eth0.hwaddr: 00:16:3e:fa:4c:45
volatile.idmap.base: "1065536"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1065536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1065536,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1065536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1065536,"Nsid":0,"Maprange":65536}]'
Pulseovernetwork:
bind: container
connect: tcp:127.0.0.1:4713
listen: tcp:127.0.0.1:4713
type: proxy
Wayland0:
bind: container
connect: unix:/run/user/1000/wayland-0
gid: "1000"
listen: unix:/mnt/wayland1/wayland-0
mode: "0777"
security.gid: "1000"
security.uid: "1000"
type: proxy
uid: "1000"
XWayland1:
bind: container
connect: unix:/tmp/.X11-unix/X1
gid: "1000"
listen: unix:/mnt/wayland1/X1
mode: "0777"
type: proxy
uid: "1000"
nictype: macvlan
parent: enp3s0
gamesold:
path: /media/Games
shift: "true"
source: /media/Games
linuxgamedata:
path: /media/[...]/linux_games/
shift: "true"
source: /media/[...]/linux_games/
mygpu:
type: gpu
pool: one
steamdata:
path: /media/[...]/steam1_stuff
shift: "true"
source: /media/[...]/steam1_stuff
winedata2:
path: /media/[...]/winedata2/
shift: "true"
source: /media/[...]/winedata2/
winedata3:
path: /media/[...]/winedata3/
shift: "true"
source: /media/[...]/winedata3/
- macvlan1
- gamingplus
- wayland1
- xwayland1
Note: For privacy reasons I replaced parts of the paths with […], but these are regular paths which always worked fine.
lxc info:
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: [...]
driver: lxc
driver_version: 4.0.4
firewall: xtables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "true"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.7.12-arch1-1
lxc_features:
cgroup2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Arch Linux
os_version: ""
project: default
server: lxd
server_clustered: false
server_name: dalaran
server_pid: 938
server_version: "4.4"
storage: btrfs
storage_version: "5.7"
