I’m a bit inexperienced with both go & with text encoding and would appreciate any insights that are available…
when running in ruby:
retval = hyperkit.execute_command(container_name, command, wait_for_websocket: true, interactive: false, sync: false)
which calls LXD’s /1.0/containers/<name>/exec REST endpoint with those options. I get and successfully establish a number of websocket connections in order to capture the output.
Backstory:
I’ve gone through a couple of websocket libraries on my receiving end, but keep encountering issues that I didn’t like, so then I move on to the next library. They all gave me actual text messages in a Ruby string (when they worked), so this wasn’t an issue with them. But I’ve now settled on faye/websocket-driver-ruby and they actually give me binary messages (on stdout e.g.), from the LXD host, instead of text messages.
This implementation does seem more ‘raw’ and from digging through your code I found https://github.com/lxc/lxd/blob/master/shared/network.go#L170-L176 (enter my go newb-ness) If I read that right, you are in fact sending binary? (L183 has me scratching my head) If that’s right, though, I’d be willing to bet that the past libs did some text encoding for me under the hood. They were pretty high-level.
####Questions:
(assuming I’m not in the rabbit-hole of a bad websocket impl - are you sending text?)
- could I send an encoding header during the HTTP upgrade-to-websocket process and would it be honored?
- (enter my encoding newb-ness) I’m responding at this point in time with:
I have validated that I get an Array of Int’s, instead of a string. (This impl sends both text and binary through the same event handler). ev.data.pack('U*') interprets the array as UTF8 and returns a string. Safe move? Or is there something more deterministic that I should be doing? A different more generic encoding? (This of course works for me with en_US.UTF8). But what happens when the container is not running ASCII or UTF8 by default?
Or is there some other way for us to communicate the encoding?
Or do I need to carry this issue to faye/websocket-driver-ruby because you are sending text?
