lxd 3.0.3
Log:
lxc liu-ubuntu-8002 20230809141446.842 ERROR conf - conf.c:run_buffer:335 - Script exited with status 1
lxc liu-ubuntu-8002 20230809141446.842 ERROR conf - conf.c:lxc_setup:3589 - Failed to run mount hooks
lxc liu-ubuntu-8002 20230809141446.842 ERROR start - start.c:do_start:1263 - Failed to setup container "liu-ubuntu-8002"
lxc liu-ubuntu-8002 20230809141446.843 ERROR sync - sync.c:__sync_wait:62 - An error occurred in another process (expected sequence number 5)
lxc liu-ubuntu-8002 20230809141446.843 WARN network - network.c:lxc_delete_network_priv:2589 - Operation not permitted - Failed to remove interface "eth0" with index 36
lxc liu-ubuntu-8002 20230809141446.843 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:842 - Received container state "ABORTING" instead of "RUNNING"
lxc liu-ubuntu-8002 20230809141446.843 ERROR start - start.c:__lxc_start:1939 - Failed to spawn container "liu-ubuntu-8002"
lxc 20230809141446.846 WARN commands - commands.c:lxc_cmd_rsp_recv:132 - Connection reset by peer - Failed to receive response for command "get_state"
config
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20230210)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20230210"
image.version: "18.04"
limits.cpu.allowance: 80%
limits.memory: 64GB
security.nesting: "True"
security.privileged: "True"
volatile.base_image: f41dafa0754b7702cea2b43d95fb7c3a3b4de8e36b66d32264e84d72ac9b0b66
volatile.eth0.hwaddr: 00:16:3e:30:a3:cc
volatile.idmap.base: "0"
volatile.idmap.next: '[]'
liu_8002:
connect:**********:8002
listen:**********:8002
type: proxy
