When launching a container the container builds but then fails to start. Syslog has an error about being unable to read cpusets:
Apr 8 15:31:50 pirx lxd.daemon[4001]: time="2022-04-08T15:31:50+02:00" level=error msg="Error reading host's cpuset.cpus"
I’ve tried to launch both a focal and an impish container with similar results.
Host is impish, running latest/stable: 5.0.0-c5bcb80
It seems this could be a cgroups incompatib. however I’m not sure why it would fail even when container and host are on the same release (impish)
Any pointers?
stgraber
(Stéphane Graber)
April 8, 2022, 2:37pm
2
How does it fail to start exactly?
Pretty much silently. The lxc launch returns, I only see it being “Stopped” when doing lxc list
Same with lxc start.
The only indication of a fault is in the syslog
Some more context from syslog
Apr 8 13:57:47 pirx kernel: [18410.174073] lxdbr0: port 2(vethd753a130) entered blocking state
Apr 8 13:57:47 pirx kernel: [18410.174076] lxdbr0: port 2(vethd753a130) entered forwarding state
Apr 8 13:57:47 pirx systemd[3816]: snap.lxd.lxc.6b75d365-4f9b-4017-a0d6-a8d2977bfed2.scope: Deactivated successfully.
Apr 8 13:57:47 pirx systemd[3816]: Started snap.lxd.lxc.1c7a177e-88bc-48fa-a4fd-a8650fa79676.scope.
Apr 8 13:57:47 pirx kernel: [18410.305205] lxdbr0: port 2(vethd753a130) entered disabled state
Apr 8 13:57:47 pirx kernel: [18410.345068] lxdbr0: port 2(vethd753a130) entered blocking state
Apr 8 13:57:47 pirx kernel: [18410.345073] lxdbr0: port 2(vethd753a130) entered forwarding state
Apr 8 13:57:47 pirx kernel: [18410.365369] lxdbr0: port 2(vethd753a130) entered disabled state
Apr 8 13:57:47 pirx systemd-resolved[2269]: veth65f63a64: Bus client set search domain list to: lxd
Apr 8 13:57:47 pirx dnsmasq[4443]: using local addresses only for domain lxd
Apr 8 13:57:47 pirx NetworkManager[2366]: <info> [1649419067.7713] device (vethd753a130): released from master device lxdbr0
Apr 8 13:57:47 pirx systemd[3816]: snap.lxd.lxc.1c7a177e-88bc-48fa-a4fd-a8650fa79676.scope: Deactivated successfully.
Apr 8 13:57:48 pirx lxd.daemon[4001]: time="2022-04-08T13:57:48+02:00" level=error msg="Error reading host's cpuset.cpus"
Apr 8 13:57:48 pirx kernel: [18411.207777] audit: type=1400 audit(1649419068.567:214): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-charmcraft_charmcraft-cloudsupport-35528151-0-0-amd64_</var/snap/lxd/common/lxd>" pid=113580 comm="apparmor_parser"
zambal
(Vincent Siliakus)
May 25, 2022, 9:24am
4
I am experiencing the same issue. Did you found any solution?
johnt
(John Thompson)
May 28, 2022, 12:14am
6
Previously (although I don’t know how many versions ago), I had unprivileged containers working on manjaro. I’ve followed all the arch how-to’s and searched online for a while, but, I’ve come up empty as to why all of my containers on lxd will NOT start.
Here is the debug output from one container.
lxc start test-debian --debug
DEB…
This may be what I’m running into as well. It just silently fails and lxd complains it can’t find the hosts cpuset. Ironically though, I have configured systemd to set that in the cgroups.
cat /sys/fs/cgroup/user.slice/user-1000.slice/cgroup.controllers
cpuset cpu io memory pids
They still do not start.
