I’m running Arch Linux on both the containers and the host. Using version 4.13. The container has security.idmap.isolated: "true" and security.nesting: "true" in its config and it’s unprivileged.
My goal is to create an LXD container to use for running saned, creating a shared network scanner. A scanner is connected to the computer using USB.
I add the device with the following addition to the container’s config while the container is already running:
$scanner-name:
productid: $product-id
type: usb
vendorid: $vendor-id
I can use the USB device in the container now and it works fine. But when I restart the container, it starts but it’s messed up:
- This shows up in
# lxc info --show-log $container-name:
lxc $container-name $date ERROR utils - utils.c:open_devnull:1286 - Operation not permitted - Can't open /dev/null
lxc $container-name $date WARN start - start.c:do_start:1358 - Failed to ajust stdio permissions
- Running
# htopin the container:
PID USER PRI NI VIRT RES SHR S CPU%-MEM% TIME+ Command
1 root 20 0 16352 5892 3940 S 0.0 0.1 0:00.96 /sbin/init
269 root 20 0 7484 3596 3120 S 0.0 0.0 0:00.00 bash
272 root 20 0 8692 4324 3220 R 0.0 0.1 0:00.02 htop
275 root 20 0 16356 4272 2316 S 0.0 0.1 0:00.00 (journald)
276 root 20 0 16356 4144 2188 S 0.0 0.1 0:00.00 (md-udevd)
$ ls -al /dev:
total 4.0K
drwxr-xr-x 10 root root 520 Apr 12 14:09 .
drwxr-xr-x 1 root root 122 Apr 8 21:11 ..
drwxr-xr-x 4 root root 80 Apr 12 14:09 .lxc
-r--r--r-- 1 root root 37 Apr 12 14:09 .lxc-boot-id
drwx--x--x 2 nobody nobody 40 Apr 12 13:52 .lxd-mounts
drwxr-xr-x 3 root root 60 Apr 12 14:09 bus
c--x--x--- 1 root root 136, 2 Apr 12 14:09 console
lrwxrwxrwx 1 root root 11 Apr 12 14:09 core -> /proc/kcore
lrwxrwxrwx 1 root root 13 Apr 12 14:09 fd -> /proc/self/fd
crw-rw-rw- 1 nobody nobody 1, 7 Apr 12 13:48 full
crw-rw-rw- 1 nobody nobody 10, 229 Apr 12 13:48 fuse
lrwxrwxrwx 1 root root 28 Apr 12 14:09 log -> /run/systemd/journal/dev-log
drwxr-xr-x 2 nobody nobody 60 Apr 12 13:51 lxd
drwxrwxrwt 2 nobody nobody 40 Apr 12 13:48 mqueue
drwxr-xr-x 2 root root 60 Apr 12 14:09 net
crw-rw-rw- 1 nobody nobody 1, 3 Apr 12 13:48 null
crw-rw-rw- 1 root root 5, 2 Apr 12 14:29 ptmx
drwxr-xr-x 2 root root 0 Apr 12 14:09 pts
crw-rw-rw- 1 nobody nobody 1, 8 Apr 12 13:48 random
drwxrwxrwt 2 root root 40 Apr 12 14:09 shm
lrwxrwxrwx 1 root root 15 Apr 12 14:09 stderr -> /proc/self/fd/2
lrwxrwxrwx 1 root root 15 Apr 12 14:09 stdin -> /proc/self/fd/0
lrwxrwxrwx 1 root root 15 Apr 12 14:09 stdout -> /proc/self/fd/1
crw-rw-rw- 1 nobody nobody 5, 0 Apr 12 14:26 tty
crw-rw-rw- 1 nobody nobody 1, 9 Apr 12 13:48 urandom
crw-rw-rw- 1 nobody nobody 1, 5 Apr 12 13:48 zero
- Everything in
/procand/sysincluding the directories themselves are owned by the usernobodyand the groupnobody. -
# systemctl --failed:
UNIT LOAD ACTIVE SUB DESCRIPTION
● tmp.mount loaded failed failed Temporary Directory (/tmp)
● systemd-remount-fs.service loaded failed failed Remount Root and Kernel File Systems
● systemd-sysctl.service loaded failed failed Apply Kernel Variables
● systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
● systemd-journald-audit.socket loaded failed failed Journal Audit Socket
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
5 loaded units listed.
I can’t view the logs of those services via systemctl status or journalctl -u, though.
$ cat /dev/random /dev/urandom /dev/zero /dev/null
cat: /dev/random: Operation not permitted
cat: /dev/urandom: Operation not permitted
cat: /dev/zero: Operation not permitted
cat: /dev/null: Operation not permitted
If I unplug the USB device from the computer or start the container without the USB device in the config, then it starts fine. The gid, uid, mode, and required: true options don’t fix the issue. I use some of them anyway.
I used to do this in the past (maybe 2-5 months ago) and it worked fine. Then I stopped doing it and wanted to do it again now and it doesn’t work anymore, so I believe that maybe a new update broke it. I am using a different computer for this but I tried it on the old one now (which has updated LXD version) and it didn’t work anymore.
