Sure, here is the config:
environment.TZ: America/Chicago
image.architecture: amd64
image.description: Debian buster amd64 (20201006_11:18)
image.os: Debian
image.release: buster
image.serial: "20201006_11:18"
image.type: squashfs
raw.idmap: |-
uid 117 105
gid 124 108
user.network-config: |
version: 2
ethernets:
addresses:
- 10.20.0.62/32
nameservers:
addresses:
- 8.8.8.8
search: []
routes:
- to: 0.0.0.0/0
via: 169.254.0.1
volatile.base_image: f87c0c968536c5c964cbc186a8b1da538612908efa43784c9fe3acb535bc74f3
volatile.eth0.host_name: vetha06eef17
volatile.eth0.hwaddr: 00:16:3e:9b:92:f4
volatile.eth0.last_state.created: "false"
volatile.eth0.name: eth0
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":105},{"Isuid":true,"Isgid":false,"Hostid":117,"Nsid":105,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1000106,"Nsid":106,"Maprange":999999894},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":108},{"Isuid":false,"Isgid":true,"Hostid":124,"Nsid":108,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1000109,"Nsid":109,"Maprange":999999891}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":105},{"Isuid":true,"Isgid":false,"Hostid":117,"Nsid":105,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1000106,"Nsid":106,"Maprange":999999894},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":108},{"Isuid":false,"Isgid":true,"Hostid":124,"Nsid":108,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1000109,"Nsid":109,"Maprange":999999891}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":105},{"Isuid":true,"Isgid":false,"Hostid":117,"Nsid":105,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1000106,"Nsid":106,"Maprange":999999894},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":108},{"Isuid":false,"Isgid":true,"Hostid":124,"Nsid":108,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1000109,"Nsid":109,"Maprange":999999891}]'
volatile.uuid: d8bb6c11-04d1-4346-a037-5e6516664210
ipv4.address: 10.20.0.62
nictype: routed
parent: enx847beb4fd13d
mysql-data:
path: /var/lib/mysql/data/
source: /containerdata/mf/mysql/data/
mysql-log:
path: /var/lib/mysql/log/
source: /containerdata/mf/mysql/log/
pool: default
- routed_10.20.0.62
ip a before sleep:
inet6 ::1/128 scope host
4: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.12.0.60/32 scope global wg0
5: lxdbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:a3:4e:f7 brd ff:ff:ff:ff:ff:ff
inet 10.25.0.1/24 scope global lxdbr0
inet6 fd42:5344:cddf:3735::1/64 scope global
17: vethc9d3c856@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether fe:51:e8:08:66:c4 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet 169.254.0.1/32 scope global vethc9d3c856
inet6 fe80::fc51:e8ff:fe08:66c4/64 scope link
23: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 44:1c:a8:e2:c6:45 brd ff:ff:ff:ff:ff:ff
inet 10.20.0.65/24 brd 10.20.0.255 scope global dynamic noprefixroute wlp2s0
valid_lft 83683sec preferred_lft 83683sec
inet6 fe80::87b2:fabc:1aab:9bf2/64 scope link noprefixroute
24: enx847beb4fd13d: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 84:7b:eb:4f:d1:3d brd ff:ff:ff:ff:ff:ff
inet 10.20.0.60/24 brd 10.20.0.255 scope global dynamic noprefixroute enx847beb4fd13d
valid_lft 72581sec preferred_lft 72581sec
inet6 fe80::a7fe:72b5:cb02:8763/64 scope link noprefixroute
25: vetha06eef17@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether fe:fe:5f:a5:98:0c brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 169.254.0.1/32 scope global vetha06eef17
inet6 fe80::fcfe:5fff:fea5:980c/64 scope link
ip r before sleep:
default via 10.20.0.1 dev enx847beb4fd13d proto dhcp metric 100
default via 10.20.0.1 dev wlp2s0 proto dhcp metric 600
10.10.24.0/24 dev wg0 scope link
10.12.0.0/24 dev wg0 scope link
10.20.0.0/24 dev enx847beb4fd13d proto kernel scope link src 10.20.0.60 metric 100
10.20.0.0/24 dev wlp2s0 proto kernel scope link src 10.20.0.65 metric 600
10.20.0.61 dev vethc9d3c856 scope link
10.20.0.62 dev vetha06eef17 scope link
10.25.0.0/24 dev lxdbr0 proto kernel scope link src 10.25.0.1 linkdown
192.168.0.0/24 dev wg0 scope link
ip neigh show proxy before sleep:
10.20.0.62 dev enx847beb4fd13d proxy
169.254.0.1 dev vetha06eef17 proxy
169.254.0.1 dev vethc9d3c856 proxy
ip a after sleep:
link/none
26: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
valid_lft 78382sec preferred_lft 78382sec
27: enx847beb4fd13d: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
valid_lft 74772sec preferred_lft 74772sec
ip r after sleep:
ip neigh show proxy after sleep:
Thanks for the help.
