Container not getting traffic on port 80
I’m having trouble sending traffic to a container… the host and container are running Debian 9 and the snap version of LXD is 3.19
I set port forwarding on the host to the container like this…
lxc config device add cco-email myport80 proxy listen=tcp:0.0.0.0:80 connect=tcp:127.0.0.1:80
lxc config device add cco-email myport8083 proxy listen=tcp:0.0.0.0:8083 connect=tcp:127.0.0.1:8083
I can access port 8083 in the container, but nothing works on port 80…
Running sudo tcpdump port 80 and '(tcp-syn|tcp-ack)!=0' on the host shows the traffic hitting the host, but the same command in the container doesn’t work and no results are shown…
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
Does anyone have any ideas?
Can you show the output of netstat -tlpn | grep :80 inside the container and on the host please.
Here’s the host
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
tcp6       0      0 :::80                   :::*                    LISTEN      -
tcp6       0      0 :::8083                 :::*                    LISTEN      -
Here’s the container…
tcp        0      0 10.112.106.223:8080     0.0.0.0:*               LISTEN      -
tcp        0      0 10.112.106.223:80       0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:8084          0.0.0.0:*               LISTEN      -
Your port 80 proxy is forwarding to 127.0.0.1:80, but inside the container there isn’t anything listening on 127.0.0.1:80, only 10.112.106.223:80.
Your port 8083 proxy should work as the container process is listening on all IPs, 0.0.0.0:8083
Ok, thank you… that’s a big help…
lxc config device add cco-email myport80 proxy listen=tcp:0.0.0.0:80 connect=tcp:10.112.106.223:u6e80
has fixed it!
Which Web server are you using? The two big ones, Apache and nginx, listen on localhost.
I was testing out HestiaCP, which is a VestaCP fork but I had a similar problem with VirtualMin… these panels use Apache and/or NGINX as selected but during this batch of testing, the control panel/web servers seem to pickup the IP of their container, hence this problem, rather than anything else, which I think is where the problem came from this time…
I’ve got another system running HA Proxy in a container which works out fine as I think it listens on all ports/addresses, as do email servers when forwarding ports 25 or 993 etc.
this worked for me :slight_smile: A Lot of Trial by Error. :slight_smile: A Lot of Fun! Have Fun! :slight_smile:
How to:
lxc config device add hcp myport80 proxy listen=tcp:HOST-IP:80 connect=tcp:CONTAINER-IP:80
Real Example:
lxc config device add hcp myport80 proxy listen=tcp:192.168.1.199:80 connect=tcp:10.212.215.20:80
