Hi all,
I created a container with lxc-2.07 on android 9.0 mobile phone which based on ARM_64 platform, the kerne version is 4.4 for android mobile phone, and the lxc-checkconfig fully meets the requirements. when I start the container, it will reboot repeatedly. the following is the the important log:
lxc_start - start.c:post_start:1439 - Started “/init” with pid “4519”.
lxc_start - start.c:signal_handler:322 - Invalid pid for SIGCHLD. Received pid 4506, expected pid 4519.
lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc_commands - commands.c:lxc_cmd_get_state:578 - Container “con1” is in “RUNNING” state.
lxc_start - start.c:signal_handler:326 - Container init process 4519 exited.
lxc_start - start.c:__lxc_start:1375 - Container “con1” is rebooting.
At the same time, I find that the PID was constantly changing as below:
State: RUNNING
PID: 6308
IP: 192.168.9.2
CPU use: 0.37 seconds
State: RUNNING
PID: 6229
IP: 192.168.9.2
CPU use: 0.36 seconds
State: RUNNING
PID: 6150
IP: 192.168.9.2
CPU use: 0.34 seconds
Not sure how to debug this issue. any way to debug and resolve this?
Thanks a lot.
BRs,
Deven
The following is a more detailed log capture:
lxc-start 20200316143420.310 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:309 - Going to wait for pid 4501.
lxc-start 20200316143420.321 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:328 - Trying to sync with child process.
lxc-start 20200316143420.327 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 4.
lxc-start 20200316143420.329 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:366 - Using pipe file descriptor 5 for monitord.
lxc-start 20200316143420.404 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:343 - Sucessfully synced with child process.
lxc-start 20200316143420.413 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:312 - Finished waiting on pid 4501.
lxc-start 20200316143420.422 INFO lxc_container - lxccontainer.c:do_lxcapi_start:804 - Attempting to set proc title to [lxc monitor] /odm2/containers con1
lxc-start 20200316143420.443 DEBUG lxc_start - start.c:setup_signal_fd:273 - Set SIGCHLD handler with file descriptor: 5.
lxc-start 20200316143420.446 DEBUG console - console.c:lxc_console_peer_default:468 - no console peer
lxc-start 20200316143420.447 INFO lxc_start - start.c:lxc_init:475 - Container “con1” is initialized.
lxc-start 20200316143420.452 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:309 - Going to wait for pid 4505.
lxc-start 20200316143420.460 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:328 - Trying to sync with child process.
lxc-start 20200316143420.464 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 4.
lxc-start 20200316143420.465 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:366 - Using pipe file descriptor 5 for monitord.
lxc-start 20200316143420.467 DEBUG lxc_start - start.c:__lxc_start:1317 - Not dropping CAP_SYS_BOOT or watching utmp.
lxc-start 20200316143420.513 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:343 - Sucessfully synced with child process.
lxc-start 20200316143420.527 INFO lxc_conf - conf.c:instantiate_veth:2647 - Retrieved mtu 1500 from br0
lxc-start 20200316143420.530 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:312 - Finished waiting on pid 4505.
lxc-start 20200316143420.530 INFO lxc_monitor - monitor.c:lxc_monitor_sock_name:185 - Using monitor socket name “lxc/abb98aa26dc9f857//odm2/containers”.
lxc-start 20200316143420.541 INFO lxc_conf - conf.c:instantiate_veth:2672 - Attached ‘vethAI4ADV’: to the bridge ‘br0’:
lxc-start 20200316143420.544 DEBUG lxc_conf - conf.c:instantiate_veth:2689 - instantiated veth ‘vethAI4ADV/veth57BT9O’, index is ‘27’
lxc-start 20200316143420.544 INFO lxc_cgroup - cgroups/cgroup.c:cgroup_init:68 - cgroup driver cgroupfs initing for con1
lxc-start 20200316143420.600 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNS.
lxc-start 20200316143420.600 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWPID.
lxc-start 20200316143420.600 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWUTS.
lxc-start 20200316143420.600 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWIPC.
lxc-start 20200316143420.600 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNET.
lxc-start 20200316143420.697 DEBUG lxc_conf - conf.c:lxc_assign_network:3185 - move ‘veth57BT9O’/’(null)’ to ‘4519’: .
lxc-start 20200316143420.791 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext3’
lxc-start 20200316143420.792 DEBUG bdev - bdev/bdev.c:find_fstype_cb:910 - mount failed with error: Device or resource busy
lxc-start 20200316143420.793 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext2’
lxc-start 20200316143420.793 DEBUG bdev - bdev/bdev.c:find_fstype_cb:910 - mount failed with error: Device or resource busy
lxc-start 20200316143420.793 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext4’
lxc-start 20200316143420.795 INFO bdev - bdev/bdev.c:find_fstype_cb:918 - mounted ‘/dev/block/loop0’ on ‘/data/maru/con1/lxc-rootfs.mount’, with fstype ‘ext4’
lxc-start 20200316143420.795 DEBUG lxc_conf - conf.c:setup_rootfs:1283 - mounted ‘/dev/block/loop0’ on ‘/data/maru/con1/lxc-rootfs.mount’
lxc-start 20200316143420.796 INFO lxc_conf - conf.c:setup_utsname:901 - ‘con1’ hostname has been setup
lxc-start 20200316143420.820 DEBUG lxc_conf - conf.c:setup_netdev:2452 - ‘eth0’ has been setup
lxc-start 20200316143420.821 INFO lxc_conf - conf.c:setup_network:2473 - network has been setup
lxc-start 20200316143420.821 INFO lxc_conf - conf.c:mount_autodev:1130 - Mounting container /dev
lxc-start 20200316143420.891 INFO lxc_conf - conf.c:mount_autodev:1153 - Mounted tmpfs onto /data/maru/con1/lxc-rootfs.mount/dev
lxc-start 20200316143420.892 INFO lxc_conf - conf.c:mount_autodev:1171 - Mounted container /dev
lxc-start 20200316143420.934 INFO lxc_conf - conf.c:fill_autodev:1199 - Creating initial consoles under container /dev
lxc-start 20200316143420.935 INFO lxc_conf - conf.c:fill_autodev:1210 - Populating container /dev
lxc-start 20200316143420.936 INFO lxc_conf - conf.c:fill_autodev:1247 - Populated container /dev
lxc-start 20200316143420.938 INFO lxc_conf - conf.c:setup_dev_console:1495 - console has been setup
lxc-start 20200316143420.940 INFO lxc_utils - utils.c:mount_proc_if_needed:1790 - I am 1, /proc/self points to ‘1’
lxc-start 20200316143420.946 DEBUG lxc_conf - conf.c:setup_rootfs_pivot_root:1108 - pivot_root syscall to ‘/data/maru/con1/lxc-rootfs.mount’ successful
lxc-start 20200316143420.973 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/0’ (9/12)
lxc-start 20200316143420.974 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/1’ (13/14)
lxc-start 20200316143420.974 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/2’ (15/16)
lxc-start 20200316143420.975 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/3’ (17/18)
lxc-start 20200316143420.975 INFO lxc_conf - conf.c:lxc_create_tty:3440 - tty’s configured
lxc-start 20200316143420.978 INFO lxc_conf - conf.c:setup_tty:1053 - 4 tty(s) has been setup
lxc-start 20200316143420.978 DEBUG lxc_conf - conf.c:setup_caps:2144 - capabilities have been setup
lxc-start 20200316143420.978 NOTICE lxc_conf - conf.c:lxc_setup:3977 - ‘con1’ is setup.
lxc-start 20200316143420.981 NOTICE lxc_start - start.c:start:1428 - Exec’ing “/init”.
lxc-start 20200316143421.276 NOTICE lxc_start - start.c:post_start:1439 - Started “/init” with pid “4519”.
lxc-start 20200316143421.287 WARN lxc_start - start.c:signal_handler:322 - Invalid pid for SIGCHLD. Received pid 4506, expected pid 4519.
lxc-start 20200316143421.311 DEBUG lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc-start 20200316143421.356 DEBUG lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc-start 20200316143421.371 DEBUG lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc-start 20200316143421.389 DEBUG lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc-start 20200316143421.419 DEBUG lxc_commands - commands.c:lxc_cmd_handler:893 - Peer has disconnected.
lxc-start 20200316143421.419 DEBUG lxc_commands - commands.c:lxc_cmd_get_state:578 - Container “con1” is in “RUNNING” state.
lxc-start 20200316143421.960 DEBUG lxc_start - start.c:signal_handler:326 - Container init process 4519 exited.
lxc-start 20200316143421.961 DEBUG lxc_start - start.c:__lxc_start:1375 - Container “con1” is rebooting.
lxc-start 20200316143421.962 DEBUG lxc_start - start.c:__lxc_start:1387 - Pushing physical nics back to host namespace
lxc-start 20200316143421.962 DEBUG lxc_start - start.c:__lxc_start:1390 - Tearing down virtual network devices used by container “con1”.
lxc-start 20200316143421.962 INFO lxc_conf - conf.c:lxc_delete_network:3005 - Interface “(null)” with index 27 already deleted or existing in different network namespace.
lxc-start 20200316143422.275 INFO lxc_conf - conf.c:lxc_delete_network:3040 - Removed interface “vethAI4ADV” from host.
lxc-start 20200316143422.276 INFO lxc_error - error.c:lxc_error_set_and_log:54 - Child <4519> ended on signal (1).
lxc-start 20200316143422.374 INFO lxc_container - lxccontainer.c:do_lxcapi_start:884 - container requested reboot
lxc-start 20200316143422.375 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 5.
lxc-start 20200316143422.376 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 24.
lxc-start 20200316143422.378 DEBUG lxc_start - start.c:setup_signal_fd:273 - Set SIGCHLD handler with file descriptor: 5.
lxc-start 20200316143422.380 DEBUG console - console.c:lxc_console_peer_default:468 - no console peer
lxc-start 20200316143422.380 INFO lxc_start - start.c:lxc_init:475 - Container “con1” is initialized.
lxc-start 20200316143422.400 DEBUG lxc_start - start.c:__lxc_start:1317 - Not dropping CAP_SYS_BOOT or watching utmp.
lxc-start 20200316143422.430 INFO lxc_conf - conf.c:instantiate_veth:2647 - Retrieved mtu 1500 from br0
lxc-start 20200316143422.439 INFO lxc_conf - conf.c:instantiate_veth:2672 - Attached ‘veth79QY0C’: to the bridge ‘br0’:
lxc-start 20200316143422.443 DEBUG lxc_conf - conf.c:instantiate_veth:2689 - instantiated veth ‘veth79QY0C/vethPS1H80’, index is ‘29’
lxc-start 20200316143422.443 INFO lxc_cgroup - cgroups/cgroup.c:cgroup_init:68 - cgroup driver cgroupfs initing for con1
lxc-start 20200316143423.766 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNS.
lxc-start 20200316143423.766 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWPID.
lxc-start 20200316143423.766 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWUTS.
lxc-start 20200316143423.766 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWIPC.
lxc-start 20200316143423.767 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNET.
lxc-start 20200316143423.873 DEBUG lxc_conf - conf.c:lxc_assign_network:3185 - move ‘vethPS1H80’/’(null)’ to ‘4572’: .
lxc-start 20200316143423.971 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext3’
lxc-start 20200316143423.972 DEBUG bdev - bdev/bdev.c:find_fstype_cb:910 - mount failed with error: Device or resource busy
lxc-start 20200316143423.973 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext2’
lxc-start 20200316143423.973 DEBUG bdev - bdev/bdev.c:find_fstype_cb:910 - mount failed with error: Device or resource busy
lxc-start 20200316143423.974 DEBUG bdev - bdev/bdev.c:find_fstype_cb:902 - trying to mount ‘/dev/block/loop0’->’/data/maru/con1/lxc-rootfs.mount’ with fstype ‘ext4’
lxc-start 20200316143423.975 INFO bdev - bdev/bdev.c:find_fstype_cb:918 - mounted ‘/dev/block/loop0’ on ‘/data/maru/con1/lxc-rootfs.mount’, with fstype ‘ext4’
lxc-start 20200316143423.975 DEBUG lxc_conf - conf.c:setup_rootfs:1283 - mounted ‘/dev/block/loop0’ on ‘/data/maru/con1/lxc-rootfs.mount’
lxc-start 20200316143423.975 INFO lxc_conf - conf.c:setup_utsname:901 - ‘con1’ hostname has been setup
lxc-start 20200316143424.213 DEBUG lxc_conf - conf.c:setup_netdev:2452 - ‘eth0’ has been setup
lxc-start 20200316143424.259 INFO lxc_conf - conf.c:setup_network:2473 - network has been setup
lxc-start 20200316143424.304 INFO lxc_conf - conf.c:mount_autodev:1130 - Mounting container /dev
lxc-start 20200316143424.373 INFO lxc_conf - conf.c:mount_autodev:1153 - Mounted tmpfs onto /data/maru/con1/lxc-rootfs.mount/dev
lxc-start 20200316143424.378 INFO lxc_conf - conf.c:mount_autodev:1171 - Mounted container /dev
lxc-start 20200316143424.668 INFO lxc_conf - conf.c:fill_autodev:1199 - Creating initial consoles under container /dev
lxc-start 20200316143424.669 INFO lxc_conf - conf.c:fill_autodev:1210 - Populating container /dev
lxc-start 20200316143424.681 INFO lxc_conf - conf.c:fill_autodev:1247 - Populated container /dev
lxc-start 20200316143424.693 INFO lxc_conf - conf.c:setup_dev_console:1495 - console has been setup
lxc-start 20200316143424.707 INFO lxc_utils - utils.c:mount_proc_if_needed:1790 - I am 1, /proc/self points to ‘1’
lxc-start 20200316143424.746 DEBUG lxc_conf - conf.c:setup_rootfs_pivot_root:1108 - pivot_root syscall to ‘/data/maru/con1/lxc-rootfs.mount’ successful
lxc-start 20200316143424.988 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/0’ (9/12)
lxc-start 20200316143424.995 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/1’ (13/14)
lxc-start 20200316143424.100 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/2’ (15/16)
lxc-start 20200316143424.100 DEBUG lxc_conf - conf.c:lxc_create_tty:3429 - allocated pty ‘/dev/pts/3’ (17/18)
lxc-start 20200316143424.100 INFO lxc_conf - conf.c:lxc_create_tty:3440 - tty’s configured
lxc-start 20200316143424.103 INFO lxc_conf - conf.c:setup_tty:1053 - 4 tty(s) has been setup
lxc-start 20200316143424.104 DEBUG lxc_conf - conf.c:setup_caps:2144 - capabilities have been setup
lxc-start 20200316143424.104 NOTICE lxc_conf - conf.c:lxc_setup:3977 - ‘con1’ is setup.
lxc-start 20200316143424.111 NOTICE lxc_start - start.c:start:1428 - Exec’ing “/init”.
lxc-start 20200316143424.119 NOTICE lxc_start - start.c:post_start:1439 - Started “/init” with pid “4572”.
lxc-start 20200316143424.123 WARN lxc_start - start.c:signal_handler:322 - Invalid pid for SIGCHLD. Received pid 4552, expected pid 4572.
lxc-start 20200316143424.991 DEBUG lxc_start - start.c:signal_handler:326 - Container init process 4572 exited.
lxc-start 20200316143424.997 DEBUG lxc_start - start.c:__lxc_start:1375 - Container “con1” is rebooting.
