I add some disk paths by lxc config device add:
lxc config set trusty raw.idmap “both $UID 1000”
lxc config device add trusty onedrive disk source=/mnt/HGST1/OneDrive path=/home/alvin/OneDrive
lxc config device add trusty working disk source=/mnt/HGST1/Working path=/home/alvin/Working
lxc config device add trusty repos disk source=/home/alvin/repos path=/home/alvin/repos
lxc config device add trusty hgst2 disk source=/mnt/HGST2 path=/mnt/HGST2 -
lxc config show trusty > old-config
lxc delete trusty
lxc init 6af0a0d3ae8a trusty
lxc config edit trusty < old-config
Launch lxc, user files in home folder has incorrect owner/group nobody/nogroup, the mapping devices has correct uid/gid 1000 though.
My exported config listed below, what’s wrong with it?
If I do not use lxc config edit but do lxc config device add again, there’s no problem at all. I export the config again and see no differences.
image.architecture: x86_64
image.description: Ubuntu 14.04 LTS server (20180703)
image.os: ubuntu
image.release: trusty
raw.idmap: both 1000 1000
volatile.base_image: 644c2d77819fb48c6d8b9fa35bfe25d11cc759c3726c42eefe22e513a7e4d937
volatile.eth0.hwaddr: 00:16:3e:a2:12:27
volatile.idmap.base: "0"
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":999998999}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":999998999}]'
hgst2:
path: /mnt/HGST2
source: /mnt/HGST2
onedrive:
path: /home/alvin/OneDrive
source: /mnt/HGST1/OneDrive
repos:
path: /home/alvin/repos
source: /home/alvin/repos
working:
path: /home/alvin/Working
source: /mnt/HGST1/Working
