Containers do not launch on Linux 5.12
[ 2842.768889] lxdbr0: port 3(veth8a78ee33) entered blocking state
[ 2842.768922] lxdbr0: port 3(veth8a78ee33) entered disabled state
[ 2842.769238] device veth8a78ee33 entered promiscuous mode
[ 2842.769303] audit: type=1700 audit(1620311921.275:480): dev=veth8a78ee33 prom=256 old_prom=0 auid=4294967295 uid=0 gid=0 ses=4294967295
[ 2842.769679] audit: type=1300 audit(1620311921.275:480): arch=c000003e syscall=46 success=yes exit=40 a0=3 a1=7ffcdbe2be00 a2=0 a3=55a65eb042a0 items=0 ppid=2237 pid=6269 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip" exe="/usr/bin/ip" key=(null)
[ 2842.769695] audit: type=1327 audit(1620311921.275:480): proctitle=6970006C696E6B007365740064657600766574683861373865653333006D6173746572006C7864627230
[ 2843.104997] audit: type=1334 audit(1620311921.608:481): prog-id=74 op=LOAD
[ 2843.105014] audit: type=1300 audit(1620311921.608:481): arch=c000003e syscall=321 success=yes exit=14 a0=5 a1=7ffc62ac1840 a2=78 a3=7f832d373010 items=0 ppid=1 pid=6280 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="lxd" exe="/usr/bin/lxd" key=(null)
[ 2843.105035] audit: type=1327 audit(1620311921.608:481): proctitle=5B6C7863206D6F6E69746F725D202F7661722F6C69622F6C78642F636F6E7461696E6572732077656B616E33
[ 2843.105124] audit: type=1334 audit(1620311921.608:482): prog-id=74 op=UNLOAD
Doesn’t look like it.
For the record, I reproduced this on two systems.
Wait, can you do
getcap /usr/bin/newuidmap
getcap /usr/bin/newgidmap
please?
/usr/bin/newuidmap cap_setuid=ep
/usr/bin/newgidmap cap_setgid=ep
Strange my version of Archlinux doesn’t even have those bits set. Weird.
Are there any Archlinux specific patches? Security modules?
@Foxboron I’m testing a fix in LXC. I think we can treat this as a LXC regression as other tools won’t be affected by this very likely.
I wanted to try reproduce it with an lxd Arch vm, but qemu doesn’t actually launch either :slight_smile: Please do pass me patches and I’ll do package builds with them for testing on our end!
Thanks for the quick response :slight_smile:
(This is just a testament that I should probably leave lxd in testing for a week going forward)
Oh? What error are you seeing with qemu? @stgraber might helper there. :slight_smile:
qemu-system-x86_64:/var/log/lxd/test/qemu.conf:50: memdev=mem0 is ambiguous
I’m suspecting there are more issues with the soft-deprecation of the qemu.conf going on?
λ ~ » lxc start test
Error: Failed to run: forklimits limit=memlock:unlimited:unlimited -- /usr/bin/qemu-system-x86_64 -S -name test -uuid
4e74621a-32e9-4945-a4e4-d5ec40b9b42c -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot
-no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=deny,resourcecontrol=deny -readconfig
/var/log/lxd/test/qemu.conf -pidfile /var/log/lxd/test/qemu.pid -D /var/log/lxd/test/qemu.log -chroot
/var/lib/lxd/virtual-machines/test -smbios type=2,manufacturer=Canonical Ltd.,product=LXD -runas nobody: char device
redirected to /dev/pts/7 (label console)
: Process exited with a non-zero value
Try `lxc info --show-log test` for more info
λ ~ » lxc info --show-log test
Remote: unix://
Created: 2021/05/06 15:49 UTC
Status: Stopped
Type: virtual-machine
Profiles: default
Log:
Very likely. This has been quite the pita.
Is that QEMU 6.0? If so, we haven’t actually done any testing/validation on that version yet and given the list of upstream changes, we indeed expect some breakage.
Ack. I’ll try take a few stabs at the changes and see if this is easily solveable else just recommend people hold back qemu. Sadly pushed lxd before there was a new major version of qemu in the repositories :slightly_frowning_face:
@Foxboron this should fix it:
I actually compiled this on archlinux and tested it. :smiley: I haven’t had an Archlinux box in a while that was fun!
Patch for the package, and test packages uploaded for @C0rn3j to test as well (includes a 4.0.9 update to lxc).
https://pkgbuild.com/~foxboron/repos/loose-pkgs/
Works on my machine at least :slight_smile:
diff --git a/lxc/PKGBUILD b/lxc/PKGBUILD
index 4129195..4c56d51 100644
--- a/lxc/PKGBUILD
+++ b/lxc/PKGBUILD
@@ -1,4 +1,5 @@
 # Maintainer: Sergej Pupykin <pupykin.s+arch@gmail.com>
+# Maintainer: Morten Linderud <foxboron@archlinux.org>
 # Contributor: Andrea Zucchelli <zukka77@gmail.com>
 # Contributor: Daniel Micay <danielmicay@gmail.com>
 # Contributor: Jonathan Liu <net147@gmail.com>
@@ -6,7 +7,7 @@
 pkgname=lxc
 epoch=1
-pkgver=4.0.8
+pkgver=4.0.9
 pkgrel=1
 pkgdesc="Linux Containers"
 arch=('x86_64')
@@ -23,11 +24,13 @@ backup=('etc/lxc/default.conf'
        'etc/default/lxc')
 validpgpkeys=('602F567663E593BCBD14F338C638974D64792D67')
 source=("https://linuxcontainers.org/downloads/lxc/$pkgname-${pkgver}.tar.gz"{,.asc}
+       "https://patch-diff.githubusercontent.com/raw/lxc/lxc/pull/3827.patch"
        "lxc.tmpfiles.d"
        "lxc.service"
        "lxc-auto.service")
-sha256sums=('ac55852bcc7b828e82cfa4afec794dd030a030c728b7b56c0c6b671fb5af0b9b'
+sha256sums=('1fcf0610e9140eceb4be2334eb537bb9c5a213faea77c793ab3c62b86f37e52b'
             'SKIP'
+            '05031e6e12768a0928adbf2c745f11a8d9152428e0bf3ea81eee1855f27ca540'
             '10e4f661872f773bf3122a2f9f2cb13344fea86a4ab72beecb4213be4325c479'
             'bbe7e0447bc3bf5f75f312c34d647f5218024731628a5e8633b1ea1801ebe16b'
             'b31f8d6b301ab9901b43f2696bcd0babb32b96e4a59fab63a2d642e43bf26bb3')
@@ -37,6 +40,7 @@ prepare() {
   sed -i \
     -e 's|"\\"-//Davenport//DTD DocBook V3.0//EN\\""|"\\"-//OASIS//DTD DocBook XML\\" \\"https://www.oasis-open.org/docbook/xml/4.5/docbookx.dtd\\""|' \
     configure.ac
+    patch -Np1 < "$srcdir/3827.patch"
 build() {
Merged and pushed to upstream stable-4.0. If you wouldn’t mind cherry-picking this patch that would be highly appreciated. :slight_smile:
That’s
in master
and
in stable-4.0. Should apply cleanly to 4.0.8 and 4.0.9. :slight_smile:
Confirming that with this package I can now run containers on 5.12, thanks everyone!
Pushed a new package to Arch with the patch. Thanks again for the fast response!
Excellent thank you very much.
Fwiw, you likely want to also pick up
as a patch to shadow utils (newuidmap). We will be releasing a new
version of this package soon too. This will take care that root users
using newuidmap to map host uid 0 where newuidmap is compiled with
capability support don’t see any issues.
Christian
