I have come across unexpected behaviour with the Fedora images. I first noticed this behaviour in a CI job that I run using GitHub actions. I can reproduce this locally as well.
In brief:
- I start a Fedora container
- there is no network connection
- the
systemd-networkdservice is not started - if I manually start the
systemd-networkdthen networking functions as expected
I note the same behaviour with:
images:fedora/40images:fedora/40/cloudimages:fedora/41images:fedora/41/cloud
With Debian images including images:debian/12/cloud and images:debian/13/cloud, systemd-networkd starts as expected and networking functions as expected.
The last successful CI job started Sun, 23 Mar 2025 11:54:24 GMT and I first saw this error in a job starting Wed, 26 Mar 2025 07:37:45 GMT.
Steps to reproduce
Command:
incus launch images:fedora/41/cloud c1
Output:
Launching c1
Command:
incus exec c1 -- ping -c4 8.8.8.8
Output:
ping: connect: Network is unreachable
Command:
incus exec c1 -- systemctl status systemd-networkd
Output:
○ systemd-networkd.service - Network Configuration
Loaded: loaded (/usr/lib/systemd/system/systemd-networkd.service; disabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/service.d
└─10-timeout-abort.conf, 50-keep-warm.conf
/run/systemd/system/systemd-networkd.service.d
└─zzz-lxc-ropath.conf
/run/systemd/system/service.d
└─zzz-lxc-service.conf
Active: inactive (dead)
TriggeredBy: ○ systemd-networkd.socket
Docs: man:systemd-networkd.service(8)
man:org.freedesktop.network1(5)
FD Store: 0 (limit: 512)
Command:
incus exec c1 -- systemctl start systemd-networkd \
&& incus exec c1 -- ping -c4 8.8.8.8
Output:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 time=14.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 time=16.3 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=59 time=15.9 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=59 time=16.7 ms
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 14.437/15.850/16.736/0.869 ms
Confirm working setup with Debian
Command:
incus launch images:debian/12/cloud c1
Command:
Output:
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 time=16.5 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 time=16.5 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=59 time=17.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=59 time=17.2 ms
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 16.499/16.826/17.185/0.319 ms
