I’ve had a bit of trouble, as it seems the networking part of LXD isn’t hugely documented and I am having trouble deciding what interfaces I should use for my containers.
The network on my LXD host network:
eth0.3, which routes to my 1st WAN connection
eth0.4, an intranet VLAN that does not masquerade once it reaches router
eth1.2, which routes to my 2nd WAN connection
My LXD host’s routing table:
# ip r
default via 192.168.3.1 dev eth0.3 metric 204
default via 192.168.4.1 dev eth0.4 metric 205
default via 192.168.2.1 dev eth1.2 metric 206
192.168.2.0/24 dev eth1.2 proto kernel scope link src 192.168.2.253
192.168.3.0/24 dev eth0.3 proto kernel scope link src 192.168.3.254
192.168.4.0/24 dev eth0.4 proto kernel scope link src 192.168.4.254
A central DHCP server is listening on all 3 VLANs:
192.168.3.1
192.168.4.1
192.168.2.1
Ideally I’d like to be able to configure my containers with that too, not just my LXD host. That’s going to mean my containers must have different MAC addresses. I am thinking macvlan is the right interface for this.
Webapp 1
webapp1 routes to the internet via eth0.3, has it’s own IP address from my central DHCP server
webapp1 serves it’s webapp/ssh to eth0.4
Webapp 2
webapp2 routes through vpn1 container and leaves via eth1.3
webapp2 serves it’s webapp/ssh to eth0.4
vpn1
vpn1 has internal network with webapp2
vpn1 routes via eth1.3
I’m a bit unsure how the configuration of the interface that routes via eth0.3, eth0.4 and eth1.2 might go.
I’m pretty sure the connection between webapp2 and vpn would be just a bridge like:
nictype: bridged
parent: lxdbr0
nictype: bridged
parent: lxdbr0
This interface is a standard bridge to my host.
Webapp2
nictype: bridged
parent: lxdbr0
eth1:
nictype: macvlan
parent: eth0.4
For this Webapp container is bridged with vpn1, and can be accessed on the LAN via eth1 (ssh/etc)
vpn1
nictype: macvlan
parent: eth1.2
eth1:
nictype: bridged
parent: lxdbr0
For this container, it goes out my main interface eth1.2
I wonder if there’s something like “Internal Networking” mode of VirtualBox:
Internal networking This can be used to create a different kind of software-based network which is visible to selected virtual machines, but not to applications running on the host or to the outside world.
Ideally that’s what I’d like eth0 on webapp2 and eth1 of vpn1 to be. That way if the VPN goes down, my data won’t fall back to being routed out my host on vlan3 ie eth0.3.
Is there a way to do a “Internal only” network? Maybe routed is the correct one, and I have to set this up manually?
That’s fine, there’s no reason for them to do so, although I don’t see why they can’t go through the router and return.
This would allow me to create a subnet just for the containers to communicate with eachother on, (which is something I think I might do, unless there’s a better way.
In fact with this example I don’t want them communicating with the host, or leaving via the host’s IP.
I found if I didn’t set ipv4.address or ipv6.address ie 192.168.33.1 or 2001:0db8:1234:33::1 for the address none of the containers would get an IP address via DHCP.
I wonder if there is a way to do DHCP but not have leakages from app1 going via my host?
