For debugging reasons I would like to see the content the authfile that is provided to skopeo.
Which path should be travelled to see what was in files as /var/lib/incus/images/incus_client_auth_2662719387?
For what it is worth: I do have valid credentials. Example given:
$ skopeo inspect docker://dhi.io/harbor-portal:2-debian-dev | jq .Name
"dhi.io/harbor-portal"
A single thread for the same problem is enough.
run as root and see if the same works.
EDIT: to be clear, that wasn’t a complaint — easier for me to follow one thread on the same failure, that’s all.
Travelled path, for me a long walk, you are welcome to speed run it.
a dry-run:
$ skopeo-trap yeah what ever ever --authfile=/etc/hosts
so far
$ cat /dev/shm/af_data
-rw-r--r-- 1 root root 908 16 aug 11:50 /etc/hosts
$ head -n 1 /dev/shm/af_content
127.0.0.1 localhost
What is inside skopeo-trap:
#!/bin/bash
if [ $# -lt 5 ] ; then
echo "too few parameters" 1>&2
exit 1
fi
IFS='=' read -r K V <<< $5
if [ $K == '--authfile' ] ; then
cp -p $V /dev/shm/af_content
ls -l $V > /dev/shm/af_data
else
echo "param5 $5" 1>&2
exit 1
fi
echo "so far" 1>&2
exit 1
Preparation, as root
# cd /usr/bin/
# mv skopeo skopeo-aside
# ln -s /home/stappers/bin/skopeo-trap skopeo
# exit
Lure
$ incus launch harder:harbor-portal:2-debian-dev harbor
Launching harbor
Error: Failed instance creation: Failed getting remote \
image info: Failed to run: skopeo --insecure-policy \
inspect docker://dhi.io/harbor-portal:2-debian-dev --no-tags \
--authfile=/var/lib/incus/images/incus_client_auth_3271860616: exit \
status 1 (so far)
Cleanup, as root
# cd /usr/bin/
# rm skopeo
# mv skopeo-aside skopeo
# exit
Caught:
$ ls -l /dev/shm/af_*
-rw------- 1 root root 72 26 aug 15:48 /dev/shm/af_content
-rw-r--r-- 1 root root 90 26 aug 15:48 /dev/shm/af_data
$ sudo head /dev/shm/af_*
==> /dev/shm/af_content <==
{"auths":{"https://dhi.io":{"auth":"YWNjb3VudDpwJTQwc3N3MHJE"}}}
==> /dev/shm/af_data <==
-rw------- 1 root root 72 26 aug 15:48 /var/lib/incus/images/incus_client_auth_3271860616
Decoding, encoding and modified file.
Because my password contains @, not %40
$ echo YWNjb3VudDpwJTQwc3N3MHJE | base64 -d
account:p%40ssw0rD
$ echo -n account:p@ssw0rD | base64
YWNjb3VudDpwQHNzdzByRA==
$ cat /dev/shm/af_modified
{"auths":{"https://dhi.io":{"auth":"YWNjb3VudDpwQHNzdzByRA=="}}}
Running skopeo with modified authfile.
$ skopeo --insecure-policy inspect docker://dhi.io/harbor-portal:2-debian-dev --no-tags --authfile=/dev/shm/af_modified | jq .Name
Yes, with the actual @ in the password, it works.
Does this mean in tools like “incus” or “incus-compose” we should base64 the result?
For what it is worth: an actual bugreport is pending.
Bugreport created:
