I’m trying out proxox, and I was wondering if anyone has a good way to convert regular lxc containers to proxmox. Thus far I seem to be failing to do so. I appreciate any help I can get on this.
If you can use LXD then there is a tool called lxd-migrate
which you can run inside a source instance which may work.
