my current LXD host is growing out of its VM boundaries and I plan to
create a slightly larger one
copy containers over to that new LXD host
the procedure looks quite straight forward but I am wondering whether there is any trouble waiting if the LXD version of the new host (apt package on ubuntu 20.04) is different then the LXD version of the old host (apt package on 18.04)
ok, thx. I’ll try it this way then. I am on 3.0.3 (apt package) on my current 18.04 host. So I assume I try to hit the closest version (which seems to be 3.0) available via snap then.
On Ubuntu 20.04 LTS, you can install LXD 3.0.4 with the following command. You may have to remove first the existing version (sudo snap remove lxd --purge), and possibly reboot to make sure there are no remnant processes.
