Hi there,
I was hoping someone could help me. Note: Of possible extreme relevance here is that the source LXD host is running LXD in a snap - from what I can tell the container storage itself is inside the snap …
I recently had an issue where I had to send my laptop away for a warranty service. Prior to sending it away I decided to copy my containers to another laptop so I could continue onsite work for a client.
The source laptop was running Ubuntu 18.04, LXC latest version from the Ubuntu repos - version 3.0.1 it seems. Initially the destination laptop was running LXC version 2.x from the Ubuntu 16.04 repository, and I was unable to copy the containers to it due to feature flag incompatibility or somesuch, so in the end I ended up doing a “snap install lxd” on theUbuntu 16.04 machine which gave me LXD version 3.6. At this time I was able to then copy the containers to the destination and start them. I have been working for them fine for the last couple of weeks.
To summarise:
- Source: Ubuntu 18.04, LXD 3.0.1
- Destination: Ubuntu 16.04, LXD 3.6 (installed via snap)
The containers were copied by setting up a LXC remote and using: lxc copy source:containername. During this time I got a progress bar.
Now, my laptop has come back and I need to reverse the process. Currently I have the remotes set up and I can list the containers on the source (the source is now the Ubuntu 16.04 machine running LXD 3.6 via snap) and execute commands on the containers via lxc exec.
When I try the copy though, I get no progress and no data is transferred:
bob@destination:~$ lxd copy source:container
[no output, I hit Ctrl-C hours later]
I have tried “pushing” the container from the source to the destination also:
bob@source:~$ lxd copy container destination:
[again, no output…]
An empty container directory is created on the destination, but it never receives any data. I need to use “lxc delete container” to reattempt the copy.
I did find a few lines of potentially relevant information in journalctl on the destination - recall the destination machine now is an Ubuntu 18.04 running LXD 3.0.1 (not 3.6 via snap). These lines are:
Oct 18 23:52:58 dev5 lxd[1663]: lvl=warn msg="Unable to update backup.yaml at this time." name=container t=2018-10-18T23:52:58+1300
Oct 18 23:52:59 dev5 lxd[1663]: lvl=eror msg="Rsync receive failed: /var/lib/lxd/containers/container/: exit status 2: " t=2018-10-18T23:52:59+1300
Oct 18 23:52:59 dev5 lxd[1663]: err="exit status 2" lvl=eror msg="Error during migration sink" t=2018-10-18T23:52:59+1300
Oct 18 23:52:59 dev5 lxd[1663]: lvl=warn msg="Unable to update backup.yaml at this time." name=container t=2018-10-18T23:52:59+1300
The lines of particular interest is:
Exit status 2 of rsync (according to the man page of rsync) is “Protocol incompatibility”.
I am able to rsync files between the two machines without problems.
Also possibly relevant:
bob@destination:~$ lxc remote list
| NAME | URL | PROTOCOL | AUTH TYPE | PUBLIC | STATIC |
| local (default) | unix:// | lxd | tls | NO | YES |
| source | https://10.23.1.116:8443 | lxd | tls | NO | NO |
I look forward to your comments.
Cheers,
- Bob -
