In incus-compose I use the default project as a cache for images, this works cause it requires a HTTPS remote it seems.
I tried to simulate the same behaviour with the incus cli:
❯ incus remote list | grep unix
| local (current) | unix:// | incus | file access | NO | YES | NO |
❯ INCUS_PROJECT=default incus image copy fad5dfa91840 local: --target-project=test --alias ghcr-registry.jochum.dev/lxc/incus-compose/ic-healthd
Error: The source server isn't listening on the network
Is this a bug? Should incus detect that the copy is on the same server but different projects?
Thanks,
René
