Hi, I’m using Arch Linux. I have a container running with Ubuntu in it. I followed this guide to enable resource limits on the container.
Here is the output from lxc config show my-ubuntu:
image.architecture: amd64
image.description: ubuntu 24.04 LTS amd64 (release) (20240710)
image.label: release
image.os: ubuntu
image.release: noble
image.serial: "20240710"
image.type: squashfs
image.version: "24.04"
limits.cpu: "1"
limits.memory: 1024MB
volatile.base_image: 7b285c64ffc20f507c69d817df21889b53a6326b6a71e347232cf3efd013ab5a
volatile.cloud-init.instance-id: c26b9fde-f2f9-46e9-8f40-815ab4e4cf65
volatile.eth0.host_name: veth9e5c78b1
volatile.eth0.hwaddr: 00:16:3e:03:ae:6d
volatile.idmap.base: "0"
volatile.uuid: 53127fce-f918-4420-a1fc-de773784d2f7
volatile.uuid.generation: 53127fce-f918-4420-a1fc-de773784d2f7
devices: {}
- 1cpu1gb
Container’s memory:
root@my-ubuntu:~# free -h
total used free shared buff/cache available
Mem: 976Mi 46Mi 735Mi 164Ki 189Mi 929Mi
Swap: 976Mi 0B 976Mi
My CPU:
root@my-ubuntu:~# lscpu
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 12
On-line CPU(s) list: 3
Off-line CPU(s) list: 0-2,4-11
Vendor ID: GenuineIntel
Model name: Intel(R) Core(TM) i5-14500
CPU family: 6
Model: 191
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 1
Stepping: 2
CPU(s) scaling MHz: 29%
CPU max MHz: 5000.0000
CPU min MHz: 800.0000
BogoMIPS: 5224.00
It shows CPU(s): 12. And, well, the output is the same on my host machine, so I think something is not set up correctly. Maybe some cgroup stuff?
How do I diagnose and fix this?
